Good point, thanks... (for both comments)
@Civic03
you can get larger fonts in windows without setting your dpi to 120. I never change the dpi cause there is allways some app that hates it.
Display Properties>Appearance>Font size
beer replenishment fund
mp3car live search
PROGRESS 95%[//////////■]Complete - Software configurations
Current Task: Just adding on...
Needed:wireless keyboard/mouse
My Carputer Blog
Car System Site
Unable to D/L skin from posted link.
Is it also possible to use Mapmonkey or Freedrive? I have FreeDrive configured in RRconfig but it doesn't start up when I click on the GPS button in the skin. When I click the GPS button RR tries to startup iGuidance, because I don't have iGuidance installed i get an error messege. How can I use MM or FD?
Hardware: Via Epia M10000, 512MB DDR RAM, 3,5" 40 Gig HD, slimline DVD-ROM & CD-R/RW, M1-ATX (PSU).
Software: Roadrunner, Mapmonkey/Freedrive
My Car PC project
FD & MM voices
Thanks for this, I am using skinbedder, and I also have Iquidence installed in its default location, the problem is I point to skin bedder in rr, and it opens up a default skin not matching LSX skin, and it opens up outside RR
Where are the proper GPS install instructions located?
-Devin
Originally Posted by liquid_smoke
Maybe that's your problem, you're not to put the skinbedder path in RR. Just leave that as it was pointing to iGuidance. The SKIN will open skinbedder and run it; it's in the configuration files that came with the skin.Originally Posted by devin98
My Carputer Blog
Car System Site
So in RR, I have it pointing to external? and point it to Iguidence.exe?Originally Posted by Civic03
sorry for all this, I am still pretty new to this whole thing
-Devin
Yes, try that. Make sure your path to skinbedder is correct in all other configuations though. If you put it in the default location you should be fine. Also make sure LSTOOLS is the root of road runner.Originally Posted by devin98
My Carputer Blog
Car System Site
This is what I did:
I Pointed RR to iguidence.exe in its default location, and set it to external GPS, however when I click GPS in RR using the LSX skin it opens up a different window with iguidence.
Iguidence is install in its default location
-Devin
By root of road running you mean:Originally Posted by Civic03
c:\program files\road runner\LSTOOLS
-Devin
