Page 7 of 36 FirstFirst 1234567891011121314151617 ... LastLast
Results 61 to 70 of 356
Thread: LSX....formerly LS3.0
  1. #61
    Constant Bitrate randomjohn's Avatar
    Sep 2005
    CT
    Quote Originally Posted by devin98
    This is what I did:
    I Pointed RR to iguidence.exe in its default location, and set it to external GPS, however when I click GPS in RR using the LSX skin it opens up a different window with iguidence.
    Iguidence is install in its default location
    -Devin
    Are you sure you're spelling it correctly? You keep spelling it iguidence here but it's iguidAnce
    GA-K8VM800M, Sempron 64 2800+, 512mb DDR400, D-Link USB BT, Linksys .11g NIC, 250gb IDE, BU-353, SIR-ALP1 w/ MJS, DSATX 220w, DWW-700H
    Worklog: http://www.mp3car.com/vbulletin/worklogs/65059-03-jetta-if-i-can-any-idiot-can.html
    Now with pictures!
  2. #62
    Jun 2002
    Virginia
    Quote Originally Posted by kbreeden
    Unable to D/L skin from posted link.
    Strike that. It downloaded fine, but I was confused because the download box didn't appear until after the download completed.
  3. #63
    May 2005
    ok I tried all that I have the LSX skin installed in
    c:\program files\road runner\skins\LSX
    the LSTools installed
    c:\program files\road runner\LSTOOLS
    RR pointing to external GPS to c:\program files\Inav\Iguidence\iguidence.exe
    it still opens a normal iguidence window externally
  4. #64
    May 2005
    Quote Originally Posted by randomjohn
    yes sorry it is spelled right, well with road runner its just point and click anyhow
  5. #65
    Maximum Bitrate Civic03's Avatar
    Dec 2005
    Which GPS option do you have checked? Is it the External one? Also LSX skins has some other folders, where did you download the ENTIRE skin to? is it in your c:\program files\road runner\skins\LSX folder? Which Skinbedder are you using? Hopefully the one he suggested. Did you also update the Exec.. ini file in the root of road runner? I suggest you read his instruction again and double check everything.
    PROGRESS 95%[//////////]Complete - Software configurations
    Current Task: Just adding on...
    Needed:wireless keyboard/mouse
    My Carputer Blog
    Car System Site
  6. #66
    May 2005
    Quote Originally Posted by Civic03
    I am using the skinbedder that came with the skin, I have external gps selected, the skin files are in c:\program files\road runner\skins\LSX
    The LSTOOLS are in c:\program files\road runner\LSTOOLS\
    Can you advise on to where his instructions are? I did not know what to update in the Exec..ini file
    -Devin
  7. #67
    Dec 2005
    I'm not on my home PC right now to tell you but maybe once I get home and can actually look at it I could be of more help. For now, backup your Exec file in the road runner root and replace that with the one in the skin and test.
    My Carputer Blog
    Car System Site
  8. #68
    May 2005
    I managed to get it working, I pointed RR to c:\program files\road runner\LSTOOLS\SKINbedder_v2.99999\Iguidance\startup.exe
    and it seemed to work
  9. #69
    Dec 2005
    In the INI file? That's where the path is suppose to be, great job.
    My Carputer Blog
    Car System Site
  10. #70
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    you dont have to copy or move the ExecTBL.ini file from the skin folder, it stays in the skin folder. RR uses both the ExecTBL.ini file that is in the root of RR and also checks the currently loaded skins folder for ExecTBL.ini and it uses the commands found in both files.
    beer replenishment fund
    mp3car live search
