I'm not sure that you can do this but you might want to try and open MM with a RUN command instead of using the GPS command
(RUN;C:/.../.../blablabla.exe;window name)
The GPS command will load the gps screen which would explain the behavior you mentioned.
LinkBack URL
About LinkBacks
