Results 1 to 3 of 3
Thread: Help w/XM list box not appearing
    Variable Bitrate Viscouse's Avatar
    Jul 2005
    Motor City
    If you're in an XM skin & hit "add channel to list" a list is supposed to pop up.
    I have all the ingredients, but for somereason, a box pops up in the center (fine) but is much smaller than is supposed to, and has the top left corner of the list skin showing.
    I can't find anything that says how to define where that list goes or how big it is, and I thought it was hard-coded.
    Why is this doing this? The Red lines I added to show for clarity.
    Here is my Xm.skin:
    Code:
    MEDIACAR Skin
    MEDIACAR XM Skin
    /, I, x, y, w, h, Code;INDICATORCODES
    I01,649,111,31,9,"TOPPL"
    I02,648,420,31,9,"BOTTOMPL"
    I05,115,529,50,55,"XMMUTE"
    I05,370,12,61,61,"SCANMODE:b"
    /, Y,  Back Slider file path
    Y01,"slider_signal\slider_*.gif"
    Y02,"slider_meter\slider_*.gif"
    /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
    S99,249,385,55,98,170,290,55,98,V,02,"slider_meter\slider_*.gif",030,"XMSAT","XM Sat Signal"
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L01,6,25,88,20,6,226,32,12,"LCD Display Grid","TIME","CENTER"
    L02,6,44,88,20,6,226,32,12,"LCD Display Grid","DATE","CENTER"
    L90,712,10,50,18,6,226,32,12,"LCD Display Grid","=CPU:","LEFT"
    L91,712,32,50,18,6,226,32,12,"LCD Display Grid","=Case:","LEFT"
    L92,709,54,50,18,6,226,32,12,"LCD Display Grid","=Load:","LEFT"
    L93,766,10,28,18,6,226,32,12,"LCD Display Grid","MBM01","0C"
    L94,766,32,28,18,6,226,32,12,"LCD Display Grid","MBM02","0C"
    L95,764,54,33,18,6,226,32,12,"LCD Display Grid","CPU","RIGHT"
    L06,479,463,161,20,0,255,64,18,"IsonormD:B","XMGENRE","LEFT"
    L08,410,462,67,22,0,160,40,18,"IsonormD","=Genre:","LEFT"
    L08,410,440,82,22,0,160,40,18,"IsonormD","=FavList:","LEFT"
    L06,495,440,145,20,0,255,64,18,"IsonormD:B","XMFAV","LEFT"
    L,250,365,54,21,0,255,64,14,"IsonormD","=Signal:","CENTER"
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B06,105,518,73,75,"XMMUTE",""
    B21,190,5,75,75,"PLAY",""
    B19,363,5,75,75,"SCANMODE","scan"
    B18,448,5,75,75,"XMFAV","next fav"
    B16,621,5,75,75,"MAIN","Home"
    B15,720,348,75,75,"XMMINUS1",""
    B15,720,435,75,75,"XMRELOAD",""
    B15,719,90,75,75,"XMNEWLIST",""
    B14,721,176,75,75,"XMDELLIST",""
    B13,722,262,75,75,"XMADD1",""
    B61,105,519,75,75,"MUTE",""
    B62,190,519,75,75,"GAMMA",""
    B64,361,519,75,75,"LOAD;lock.skin","Lock"
    B65,449,519,75,75,"QUIT",""
    B66,534,519,75,75,"MINIMIZE",""
    B67,621,519,75,75,"LOAD;exitmenu.SKIN",""
    B51,6,90,75,75,"XM","XM"
    B52,6,177,75,75,"GPS","GPS"
    B53,6,264,75,75,"AUDIO",""
    B54,6,350,75,75,"VIDEO",""
    B55,6,436,75,75,"EJECT",""
    B50,652,123,25,46,"PGUP",""
    B50,652,178,25,71,"UP",""
    B,115,113,58,36,XMCHAN;82,""
    B50,652,288,25,71,"DOWN",""
    B51,652,369,25,49,"PGDOWN",""
    /, F, x, y, w, h, Movie name
    F,644,431,37,55,"XMlogo.swf"
    /, J, x, y, w, h
    J,308,438,100,40
    /, S, x, y, w, h, forecolor R;RGB, G, B, backcolor R;RGB, G, B, played color R;RGB, G, B, selected color R;RGB, G, B, select color R;RGB, G, B, trs, font size;FONT, font name
    S01,307,114,340,312,147,222,157,000,16,000,255,245,000,6,226,32,0,0,0,TRUE,16,"IsonormD:B"
    END
    Here is the XmFavList.skin :
    Code:
    MEDIACAR Skin
    MEDIACAR XMFAVLIST Skin
    B01,5,344,230,88,"SELECT","Select"
    B02,340,344,230,87,"CANCEL","Cancel"
    B03,561,270,73,73,"PGDOWN","Pg down"
    B04,561,194,73,73,"DOWN","Down"
    B05,561,91,73,72,"UP","Up"
    B06,560,14,73,75,"PGUP","Pg up"
    I02,564,325,28,7,"BOTTOMDL"
    I01,560,13,35,10,"TOPDL"
    /, S, x, y, w, h, forecolor R;RGB, G, B, backcolor R;RGB, G, B, selected color R;RGB, G, B, select color R;RGB, G, B, trs, font size;FONT, font name
    S01,16,17,543,311,255,225,000,000,000,000,000,000,000,255,255,255,TRUE,19,"ARIAL NARROW:B"
    END
    You know you want to...Worklog
    Enjoying v1.0 since it's operational. Aaaawww yeah.
    Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
    Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
    Jul 2005
    Motor City
    Sorry for the bump. Anyone have ideas?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    sorry it took so long for me to check this thread (you should have PMed me earlier).. anyway.. the popup list size is not hard coded, it will be determined by the size of your empty image.. if your empty image is smaller, it will likely make it look like the popup is not all there.. If that's not the case with your skin, please send me the image files along with your 2 .skin files so I can try it out.
    Ride Runner RR's Myspace
  1. thumbnail view for folder and list view for file?
    By civic5zigen in forum Road Runner
    Last Post: 11-01-2005, 01:55 AM
  2. Box and In-Dash setup questions
    By Pale Rider in forum Fabrication
    Last Post: 06-11-2005, 03:40 PM
  3. Box Loudness.... Help?
    By Harlanc03 in forum Car Audio
    Last Post: 06-08-2005, 11:10 PM
  4. Motorizing my glove box...how?
    By SuperMatty in forum Classified Archive
    Last Post: 08-14-2002, 10:53 PM
  5. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
