LS, I see that you shrunk the speedo down a bit... do you want it re-sized in flash? (i think there is a quality loss when altering the size in RR)
Printable View
yeah, the way it is now is kind of just place holder. I had an idea for a graphic change but i wanted to leave it where its at now for a week or two to see if i actually wanted it like that. I think in the end i may need a graphic change (ill send you the updated psd) and one in the original size and another that is slider size. Still not sure yet, so ill get back to you when i make up my mind.Quote:
Originally Posted by DiNASTY
Ah so the menu scrolls from left to right with the main one centering in the middle? Nice concept if I'm seeing it correctly.
OK hurry up and release!! :) DiNASTY, what's up buddy? Email me.
yes that is how it worksQuote:
Originally Posted by Civic03
there will likely be some menu item reshuffle between what you see on the left arrow and right arrow, as i fill out the right arrow with more items.
But you can still select what's on the screen w/o scrolling right? In other words scrolling isn't the only way to select the item; you can just click on it.
i think i understand what you mean.
yes.
you can click anything you see on screen, nothing is just for show.
basicly, the first screen you see is the main menu, that has core functions on the top, audio, navi, dvd, phone with playbutton on the bottom, all functional. Clicking the left arrow will take you to the second menu screen with weather, ripcd, mixer , power etc.
clicking the right arrow takes you to another menu that has yet to be filled out.
It's excellent; I played with this last night. One thing I noticed is that when you click on Full screen button in Nav that full screen button on the top right doesn't go away. In fact when you exit out of RR it's still there.
how do you setup the speedo flash so that it uses the gps info? I have it loaded but its just sitting there.
you have to add a label with gpsspd, but put it off screen.Quote:
Originally Posted by Sonicxtacy02
add this to your .skin fileCode:/, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
L,-100,0,20,20,255,255,255,12,"Arial","GPSSPD",
