If i remember correctly, all you have to do is add this to the ExecTBL and load the browser instead of the audio_player right?
"ONFILECLICK","!SELECT"
"ONDIRCLICK","BROWSE"
But since its all in flash, the ExecTBL is out the window. Currently, I have the music browsing setup so that you can only:
1. Add an album to the playlist
2. Browse into ONE directory only
3. Add songs within that directory
4. Browse back
It's like this because I have my music setup like this (ALBUM FOLDERS > SONGS) as you can see in the video.
Anyways, I could easily add directory browsing to how it is now because of the way it's set up. All i need to do is change the ADD to !SELECT right? But the problem will be how to tell if there are folders within folders ie. (ARTIST > ALBUMS > SONGS) This is a flash issue so i'm not 100% sure how to approach it ATM, but I will have a look. -Thanks
LinkBack URL
About LinkBacks
