i know its beta, and i might have jumped ahead with modding flashdeck already.
first attempt to change logo. I just need to figure out how to remove that circle
Are you going to make a "800x600" flashdeck skin?
CAR:2001 Ford Crown Victoria
PC: Acer EEE 900HA with Win7 with CF 2.0.
Memory:1G
Drives:160gig
WI-FI:Cingular
GPS:IG2k9
Screen:Xenarc 700TSV
The Florida Meets Thread
The circle is fine, it's that thing in the middle you need to get rid of....LOL JK... Will test it in the car today for ya DiNASTY.
Peese
@ GizmoQ/Roy: I'm not exactly sure why it's adding the video files to the playlist like that, I will have to take a look... This was not intended, but would be cool to have it play in the albumart area. I can't use the "A" skin definition because it will cut out the flash area completely if i remember bet have a look at the app i attached (just an idea)
@john1701: For now just try and make a smaller logo (see tut on first post) I will add support for large logos in the next beta version.
@djkl407:for general.ini resize
its just my 2 cents but i just tried this and was put off by not being able to get past the config,got as far as weather and had to exit,leaving me with a non functioning flashdeck,the buttons that did nothing thanks to the config are also very small,i know there bigger than they look but what are you saving the space for?
Config's not done... just click "later" on the popup and use RRConfig.
Are you referring to the buttons on the config screen or on the player bar?
oh there's my answer then,sorry.I was refering to the buttons on the audio player bar,it took me a while to spot the trigger to get the bar up too,but i might be going blind,lol,its obvious now but wasn't at first
might i also add that its amazing what youve accomplished,mind boggling to me,some1 with no programming skills,it makes RR come alive almost,like real software if you know what i mean.Don't get me wrong the jpeg stuff is good but can't compete with this.
Thanks bro. I'll make stuff easier to see in the next beta.
i've only tested on my laptop so far... pentium centrino 2.0g, 1gb ram... my car is almost similar... 1.86ghz pentium m, 512mb ram... should be fine too...
Roy
2005 Range Rover 4.4
