Page 1 of 45 1234567891011 ... LastLast
Results 1 to 10 of 443
Thread: FlashDeck
    Maximum Bitrate DiNASTY's Avatar
    Mar 2005
    Concord, California
    Arrow FlashDeck
    Skin Progress: Revising
    How to install
    1) Get the BETA v1.2 Here (extract anywhere you please)
    2) extract "reboot.exe" to your RoadRunner directory
    3) extract the "weather" folder to your RoadRunner directory (for weather support)
    4) add the following to your KeyTbl.ini: 4081,"EXIT" (for iG support)
    5) Run FlashDeck and click on "FlashDeck Config" under "MENU->INFO->FlashDeck Config"
    NOTE: At the moment, this skin only works with flash player version 8 or earlier.
    Customized logo Tutorial Here
    comments/suggestions and donations are more than welcome
    Attached Files Attached Files
    Variable Bitrate marazi's Avatar
    Dec 2005
    Skien, Norway
    awsome....
    looks great
    Variable Bitrate jthiani's Avatar
    May 2005
    Raleigh, NC.... Nbi, Alpha quadrant (1 00 N, 38 00 E ) !!!
    file does not work on any of my video players....real player, windows media, or winamp...what gives.....???
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    What's the video codec you used?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    u guys may need this: http://www.techsmith.com/download/codecs.asp
    @Dinasty: I'm not sure of your intentions for the bottom of the screen, but I'd like to see the current song + other info on there (suggestion).. also what happened to the cool playlist editing you showed me before ? did you separate the lists ?
    Ride Runner RR's Myspace
    Jul 2004
    Berkeley, CA
    TechSmith Screen Capture Codec (TSCC) did the trick. Thanks guino.
    DiNASTY: Clean up your desktop
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    still doesn't work for me.
    edit: nevermind, works with quicktime.
    edit2: ok, but no audio, with quicktime.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Constant Bitrate Phythorian's Avatar
    Dec 2004
    Netherlands
    Nice and simple, like it!
    But will this dragging work good with a touchscreen?
    Finished!
    pc 99% - install 100% - audio 100%
    Mar 2005
    Concord, California
    Sorry bout the codec. I will try another format for the next vid.
    @Guino: Yeah, the playlist is separate now but will probably have those same effects on it. As for the bottom, there will be the Visu, Clearlist, Search, Eq, Open (playlist), Save (playlist) ect... I think I can fit the current song either on the very bottom or on the top bar. Still many buttons to add though and i don't want it to get cluttered.
    @0l33l: and that's only about 1/4 of my desktop.. guess i should run that cleanup wizard huh.
    TBH, I'm not sure that it will work out on a TS. But it should considering that you only have to drag the song slot a very short distance to add it. also, if your in a directory you can also just click to add it. (not shown)
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    cant someone just screenshot it for us using paralyzed computers (i.e via 800s lol)
