Results 1 to 9 of 9
Thread: Map Monkey Embedding
    Newbie t_reich's Avatar
    Dec 2005
    Schwanau, Germany
    Question Map Monkey Embedding
    Hi guys,
    i was searching the forum for some help on embedding MapMonkey in my RoadRunner Skin. I got it running quite good. But one thing is missing:
    I don't get it what i have to do in my mapmonkey ini-file to make these keyboard shortcuts like in other skinds (Dena, Mazda, Spaced Out) work. When I try these skins these command have no effekt on MapMonkey.
    Only the buttons with direct commands like "MM;Home" are working.
    For my skin I need to command for GO or Navigate, or how it's called.
    Thats the only button thats missing in my skin.
    could anyone please help me????
    Thorsten
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Code:
    "MM;Hotkey_CMD|FE_MENU_OPEN",""
    "MM;Hotkey_CMD|FE_MENU_ITEM_ROUTETO",""
    "MM;Hotkey_CMD|FE_MENU_ITEM_CANCELROUTE",""
    "MM;Destinate_Favorites",""
    "MM;Destinate_POI",""
    "MMDETACH||LOAD;dest_full.skin||MMEMBED",""
    "MM;Hotkey_CMD|FE_VIEW_MENU_OPEN",""
    "MM;Hotkey_CMD|FE_MENU_ITEM_SETTINGS",""
    "MM;Home","
    tja
    tja is offline
    Aug 2005
    sydney, australia
    looks familiar...
    2005 Nissan Xtrail
    DFI 855GME-MGF - Celeron M 1.4GHz - 256Mb RAM - 200Gb SATA HDD - OPUS 150w - Xenarc 700TSV
    worklog
    Dec 2005
    Schwanau, Germany
    @tja: so what? why aren't you happy that somebody else likes your work and uses it also? Why don't you release your psd's?
    tja
    tja is offline
    Aug 2005
    sydney, australia
    lol. what's this got to do with releasing my psd's? u wanna pinch my layer styles too?
    look.. i dont care if u use something from my skins. im flattered. just ask. or give credit where it is due rather than passing it off as ur own work. if you want want the layer style or the gradient fill pattern then fine i can upload it here and you can do it properly rather than cutting or pasting. that isnt a problem.
    but if u just steal from my work and my ideas then i will have to take action.
    2005 Nissan Xtrail
    worklog
    FLAC djmickyg's Avatar
    Feb 2004
    you put a gradient fill in a box..
    its hardly worth bragin about..
    did u think adobe in ur skin thread for making the software? and dont forget to thanks uncle bill gates for windows
    Aug 2004
    Germany
    @tja
    Just because he used the same gradient he steals your work ? That's ridiculous. But gave me a good laugh. Thanks for that.
    tja
    tja is offline
    Aug 2005
    sydney, australia
    Quote Originally Posted by djmickyg
    its more than he did.
    Quote Originally Posted by Konrad
    @tja
    ur welcome
    2005 Nissan Xtrail
    worklog
    Jun 2005
    You seems to have been able to do what I'm triing too (hiding the main menu bar) how you did it?
    May I ask you a little help here? no-one answer in the MM board
    Skin question
    hotkeys question
    thanks!
  1. Replies: 106
    Last Post: 10-20-2008, 09:09 AM
  2. Problem embedding Map Monkey
    By ildena in forum Road Runner
    Last Post: 02-19-2005, 01:24 AM
  3. Problem embedding Map Monkey
    By ildena in forum Map Monkey
    Last Post: 01-31-2005, 11:25 AM
  4. Embedding new Map Monkey
    Last Post: 01-31-2005, 04:31 AM
