Page 10 of 26 FirstFirst 1234567891011121314151617181920 ... LastLast
Results 91 to 100 of 255
Thread: XEON - Skin Preview
  1. #91
    Jul 2004
    NL, Druten
    hi,
    Been testing this skin on my carpc. Everything is running slow. I tried to open the flash movie in IE. This works fine. I also installed the flashplayer 8 and the flash directx plugin (FAQ). There must be something to get this working smootly. My carpc is a 2.4 Gh p4 (HT) with 512 MB. This should be enough for a simple carpc
    My desktop doesn't have any of this issues. Installs aren't that different. There must be something missing here. I installed the folowing:
    Windowsxp sp2 (+automatic updates)
    vb6 comes with freedrive
    flashplayer 8
    some codecs
    powerdvd
    bluetooth software
    and roadrunner - fresh installed and updated
    I also noticed that running the above consumes about 30% CPU while playing audio and even more while hitting buttons.. Memory consumes about 200 MB running winxp + winamp + roadrunner + bluetooth
    I know this is a little! off topic.. but does the above make any sence?? Some friends of me expierence the same. please advice..
  2. #92
    Maximum Bitrate DiNASTY's Avatar
    Mar 2005
    Concord, California
    It is normal for flash to bog down when it is in RR. I test my skins on a 3.4 GHz XPS system and I can still notice about a 10-20% decrease in performance when the flash is in RR vs. in the Player or IE. I'm also working with the lists in flash and I can tell you that it requires a TON of messing around until it's acceptable. But if anyone can get it to run smoothly, it's CdR
  3. #93
    Variable Bitrate jthiani's Avatar
    May 2005
    Raleigh, NC.... Nbi, Alpha quadrant (1 00 N, 38 00 E ) !!!
    Quote Originally Posted by CdRsKuLL
    Hi m8, yeah I did, sorry forgot to reply.. I'm not realeasing any files yet until i'm happy my code isnt locking systems up. You can have a copy of mc2 main if you like Its a bit messy but at least you can see how i'm doing things in that.
    CdR
    Hey thats cool.m8t....yeah please send the swi file for mc20 and i will wait patiently for the swi on this skin. One question though...how do you code the control of the playlist from inside the swi????
  4. #94
    Tainted Love Cris's Avatar
    Romania
    CdR, good news I'd say.
    I tried it on a 1Ghz Duron with 128SDRAM. It's a bit slow (noticeable), but definatly usable. So I'm keeping my fingers crossed it will run on the M10k.
    btw, what's the status of the skin?
  5. #95
    Nov 2004
    St Louis
    Come on guys, everybody knows CDR is the master. I got this running on my 500Mhz tablet and once I load all the screens its a little slow, but the WOW factor is amazing. One problem I have is the audio playlist and browser don't show. I can click on the blank spaces and it reacts just as if the file/directory text were there, just invisible.
  6. #96
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Flash def. slows down a bit inside RR because of the graphics transparency that it has to perform when updating the flash drawings.. this is what allows flash objects to be seamlessly transposed over RR buttons/labels and images. Believe me when I say I did and re-did a lot of research on this stuff... if the flash object is not CPU intensive, it should not take much CPU at all when in RR.. a good example are the flash logos.. CDR has done a great deal of improvements on the speed from the first versions I saw.. DiNASTY got things to work very smoothly on the tests I saw too.. I use a little celeron 1.2Ghz to test everything.. so slowly but surely, they're getting there..
    Ride Runner RR's Myspace
  7. #97
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Hi peeps.. Ill in bed at the mo with the flu, but I did do a bit yeasterday morning. I have added a slider bar to the audio browse and change how it works, much more simple when you know. Also done the Video part, ut need to port the slider over to that. One thing I did notice was if RR is getting requests from the lcd module I've done the slider keeps loosing focus.. but this i'm sure can be worked out.
    Anyway when i'm felling a bit better I will finish of the gps then do a little release.
    CdR
  8. #98
    Oct 2005
    Ahh I can't wait for a new release... This skin has me abandoning all the others.
  9. #99
    Romania
    How's it comming CdR?
  10. #100
    Mar 2005
    Concord, California
    You mean you're planning on doing a slider for the video browser list? Would that use CUSTOMDL, i'm not sure? I hope you're feeling better, drink lots of fluids -DiNASTY
  1. Spag's FD 1.0 skin development preview
    By Spaghetti in forum FreeDrive
    Last Post: 05-16-2006, 08:30 AM
  2. Roadrunner Skinning Tutorial
    By Meelobee in forum RR Skins
    Last Post: 12-30-2005, 08:28 PM
  3. flash skin preview
    By holistic in forum RR Skins
    Last Post: 07-09-2005, 05:17 AM
  4. Preview: Color-coded skin
    By ruairi in forum RR Skins
    Last Post: 04-22-2005, 04:32 AM
  5. Replies: 1
    Last Post: 02-20-2005, 10:10 PM
