Incredible.
Skully, success! No probs with opening the folders on the lappy. I have no idea why it didn't work on the desktop as I just copied all the same stuff over to the lappy. Sorry to bugger you around. Still, I guess no-one else should have an issue with it now. Cheers for the help buddy. Bloody fantastic job as usual![]()
Only true postwhores remember everything they post
REP CLUB IS DEAD
LONG LIVE REP CLUB
Incredible.
Hi m8, using swishmax to make it, along with some photoshop for the graphics.Originally Posted by Dalailama
I will be adding more modules and going back and changing more stuff over hte next week or two :-)
cheers
CdR
a few reports coming in of the audio browser locking up on some machines.. I'm looking into this at the moment see if I can fix it..
cheers
CdR
Hi CdR,
there are some bugs I found playing it on my PC:
Type you soon (can I say so?)
- When volume animation comes out the volume pops up to 62
- somethimes If I drag and drop over audio skin a little red circle appears following the mouse and then freezes, I have to kill the process from task manager! (with a touchscreen it happens often)
- 3 times on 4 when I'm working on a playlist it can't go back to previous visualization... and I can't do my playlist...or simply they aren't already be done!
or I'm not able to
Live today like it is your last day, and behave as though you will live forever...
my WEBSITE
MapMonkey Dalai skin-preview-download ITA-email me for ENG
Road Runner CrystalBlue skin-preview-beta release
CdR, if the volume is indeed bouncing back to "62" It might be that you left 62 in the dynamic text box field so whenever you remove and place it from the timeline, it reverts back to 62. This happened to me and taking that text out fixed the issue.
Hi m8..Originally Posted by Dalailama
on which part does it jump to 62 on the volume ? I've not had any problems with this ?
this red circle that appears, is it on the audio browser skin ? If it is then it should not appear as I have set the whole skin with a no gesture crop, you might of found a bug in RR if this is the case.
let me know
CdR
Thanks I will take a look and see whats in it.. :-)Originally Posted by DiNASTY
Just checked, I have 100 in it.. so unsure if thats causing the problem, will have to do some more testing
CdR
Can someone thats having the lockup problems on the audio browser skin, try this file.. just unzip and overwrite the one in the xeon folder.. www.cdrskull.com/audiolist.zip
Also, if this doesnt fix it, can you try turning your gestures off.. you can do this a few ways, I would say the easiest is by keyboard, typing blind .. "gesturesoff" include the " as well, do this before you load the audiobrowser up. Do this in the Audio screen, then you can at least test to see if there off, by stroking the screen
cheers
CdR
Hi CdR,
The volume jumps from every skin, just click on the right corner on the bottom and volume goes to 62. I've download the new swf but nothing...
The gestures red circle appeares in every skin, but in this case I've disabled it as you tell before and everything goes right...
P.S.:just for curiosity... what m8 stands for? (...I've tought mate...but my english is not so good to let me be sure...)
my WEBSITE
