Page 2 of 26 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 255
Thread: XEON - Skin Preview
  1. #11
    Maximum Bitrate DiNASTY's Avatar
    Mar 2005
    Concord, California
    Wow CdR!! I really like how you can change the colors on the fly like that. Also, the border effects are really nice. One suggestion though, the skin runs fine on my desktop, but on my P4 2.8 laptop, I was getting a constant 100% CPU load. I think It might be the border effects but I'm not positive. Any chance you could make the border effects optional?
  2. #12
    Raw Wave lostreception's Avatar
    NY
    there are ways of making a full screen flash page look amazing at like 30 fps ive seen websites running full screen tons of stuff going on and hardly any cpu usage i wish i knew the secret to optimizing flash code i need to get some books on it or something
    looks amazing so far my cpu is at like 71% tho without music playing just running the file . if i find the answer to optimization ill let you know
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
  3. #13
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Quote Originally Posted by DiNASTY
    Hi fella.. yeah on my xeon machine it works great, on my carputer.. jezz it lags like hell, so I have binned the boarder effects..
    now I have two choices.. either to play with playlists, dir lists and flash like you have.. or make a simple vb program that edits the skin files so it changes the colours on the lists to match the colours set in the txt file. Cant decide to be honest.. I have a feeling the VB option is the more simpler, but if I can get the playlists in flash it opens up more options. I have done the change of colours on the audio player and audio list so far.. the others wont take long at all now really..
    How you getting on with yours ? looking forward to seeing it :-)
    CdR
  4. #14
    Variable Bitrate jthiani's Avatar
    May 2005
    Raleigh, NC.... Nbi, Alpha quadrant (1 00 N, 38 00 E ) !!!
    This skin is tooo hot man.....CDR could you please let me have the swi file?? pretty please...all i need is the one you have so far so that i can see how you have coded the fscommands. Cheers m8t
  5. #15
    Feb 2004
    Manchester
    on (press) {
    fscommand("PLAY","BUTTONDOWN");
    on (release,releaseOutside) {
    fscommand("PLAY","BUTTONUP");
    easy really :-) I will be releasing them with the skin.. just got lots to do on it atm
  6. #16
    May 2005
    sweet...how about the labels???? and should you creat a separate box or item for each label???
  7. #17
    Feb 2004
    Manchester
    For Labels.. always make sure you have the label you want to show in flash in your .skin file.. ie..
    L,0,0,0,0,,,,,,"TRACKNAME",
    then to display it in flash, just stick a text label in and make it dynamic and put the variable name in it to match the label.. ie TRACKNAME
    hope this helps
  8. #18
    May 2005
    This helps a great deal.....good looking out...one more question..... can playlists and folder lists be controled by the swi/swf like the label and button funtions???? the reason i ask is ...for example if i wanted a flash effect to play before loading the audio browser skin, i would not like for the playlist or directory list to appear before the animation was complete....hope this makes sence.....same question for sliders, etc
  9. #19
    NY
    CDR i just remembered a great optimization for flash animations
    step1
    create the animation
    step2
    make a new movie the same size of the animation
    Step3
    copy the animation into the new movie
    step4
    export the animation as a gif
    Step 5
    make the gif its own movie
    step6
    in the last frame of the gif call the next function (showing the flash buttons)
    step7
    (flash buttons are loaded) it plays just like it did before
    if flash plays a gif vs redrawing vectors constantly it will take up less cpu
    if you were to do this with the movie im sure it would cut down on the cpu usage if you dont know what i mean i can take a look at what uve done and do it for you let me know
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  10. #20
    Feb 2004
    Manchester
    cheers for that info.. I want to do something on the main menu page..
    I have been busy adding code to enable me to use a flash playlist. .seems to be working well, I have also made it dynamic.. so you can chang ethe colour to be anyting you want just by changing a single line in a file..
    ie.
    &menucolour=077cce&
    I will be writing a VB app which will allow you to change the colour from within the skin and also reload it.. :-)
    below is a nearly finished audio skin, just want to add a dynamic menu like i did in MC2.0
  1. Spag's FD 1.0 skin development preview
    By Spaghetti in forum FreeDrive
    Last Post: 05-16-2006, 08:30 AM
  2. Roadrunner Skinning Tutorial
    By Meelobee in forum RR Skins
    Last Post: 12-30-2005, 08:28 PM
  3. flash skin preview
    By holistic in forum RR Skins
    Last Post: 07-09-2005, 05:17 AM
  4. Preview: Color-coded skin
    By ruairi in forum RR Skins
    Last Post: 04-22-2005, 04:32 AM
  5. Replies: 1
    Last Post: 02-20-2005, 10:10 PM
