Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 50
Thread: Flash Skin Tutorial?
  1. #21
    Constant Bitrate mick0uziel's Avatar
    Feb 2005
    ca
    Flash Help - FScommand
    hi, i attached my flash document for a honda logo, all i want is to run it on roadrunner. it replaces the logo of roadrunner as logo.swf, but what i want to do is when i click on the logo, it launches my obdii program, its "c:\program files\pcmscan\pcmscan.exe". i was going to use the other screens to embed it and i was going to do it like this:
    "Load;picview.skin;pcmscan;c:\program files\pcmscan\pcmscan.exe;pcmscan"
    i tried putting this on flash
    fscommand ("exec","Load;picview.skin;pcmscan;c:\program files\pcmscan\pcmscan.exe;pcmscan")
    not sure what i was doing, but can someone with flash help me make this work like show me the code or just make the movie for me, thanks so much
    Attached Files Attached Files
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
  2. #22
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    i dont think you need to have the "exec" there
    Live mp3Car Facebook Chat
  3. #23
    Maximum Bitrate DiNASTY's Avatar
    Mar 2005
    Concord, California
    mick0uziel, you might consider using the execTBL.ini for defining your commands. Then just send the defined command to RR with a fscommand.
    (This is also helpful for skinners because it allows users to change paths and take out commands all together without editing any flash movies)
    Beer is proof that God loves us and wants us to be happy Benjamin Franklin
  4. #24
    Feb 2005
    ca
    oh ok im lost now, the way i understand the previous explanations is i go back to flash and try to embed the command in there, 'fscommand (command,parameter)' is the format but i never got to run in with flash because flash doesnt understand the command "load;.....". can you guys write something up for me like the actual code that i can understand/use. the logo6animate.zip contains my flash document which you can edit. it is suppose to be simple right? i have a flash button, when i click it, its suppose to launch an application, in my case pcmscan.exe, and this program im embedding in the picview.skin which is fine right now. im almost ready to put my new carpc in my prelude so i can post my install, but i want something running. thanks again.
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
  5. #25
    Mar 2005
    Concord, California
    See posts 23, 22, 20, 18 and 2.
    You don't need "exec" in there, I would just do the following back to back:
    fscommand ("LOAD;picview.skin");
    fscommand ("RUN;C:\\Program Files\\pcmscan\\pcmscan.exe;pcmscan");
    I should have mentioned it before but if you try and "Play" the movie using player controls in Flash or Swishmax, It will automatically debug everything before it plays. Because your writing code for a projector swf and not the web, It will give you errors up the yazoo. Just ignore them.
    I would love to help you out but I don't have FlashMX installed (only Swishmax) and that would be a bit of a spoon feed i think
  6. #26
    Feb 2005
    ca
    i tried the commands that you showed me dinasty, nothing happens, is there not suppose to be an expression before the fscommand so it executes that after the movement like mouse down or click or something? thanks
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
  7. #27
    Woodbridge, VA
    Blog Entries
    53
    how to you set up the movie so that it doesnt auto-loop?
  8. #28
    Feb 2005
    ca
    OK some progress, i was able to do this:
    flash:
    on (release) {
    fscommand ("PCMSCAN");}
    RR execTBL:
    "PCMSCAN","RUN;C:\PROGRAM FILES\PCMSCAN\PCMSCAN.EXE"
    it works upto this point..
    then i tried putting the skin by adding the skin and it looked like this:
    "PCMSCAN","RUN;C:\PROGRAM FILES\PCMSCAN\PCMSCAN.EXE",PICVIEW.SKIN
    after that i ran the RR again, click on the link, and all it did was pronounced the name PCMSCAN, and thats it nothing happened.
    if i load the skin like this:
    "PCMSCAN","LOAD;PICVIEW.SKIN"
    the picview skin loads.
    now what do i need to type so i can run the pcmscan program inside the picview.skin in RR? i need to put this in execTBL. thanks
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
  9. #29
    Woodbridge, VA
    Blog Entries
    53
    my first guess would be try single quotes. Why not just load it like this
    "LOAD;PCMSCAN.SKIN;PCMSCAN;C:\YOUR PATH\PCMSCAN.exe;PCMSCAN"
  10. #30
    Feb 2005
    ca
    i tried that and it doesnt respond
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
  1. Flash Skin .Fla help with commands
    By neon_eddy in forum Road Runner
    Last Post: 07-18-2008, 05:18 PM
  2. Full Flash Skin
    By camsgs3 in forum Road Runner
    Last Post: 01-04-2006, 06:40 PM
  3. flash skin preview
    By holistic in forum RR Skins
    Last Post: 07-09-2005, 04:17 AM
  4. New Skin - Spaced_Out for FrodoPlayer 1.08
    By WeeZyFellA in forum FrodoPlayer
    Last Post: 10-17-2004, 09:50 PM
  5. v.3 SKIN
    Last Post: 10-15-2004, 08:29 PM
