Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 50
Thread: Flash Skin Tutorial?
  1. #31
    Constant Bitrate mick0uziel's Avatar
    Feb 2005
    ca
    strange, i retyped it again and now it works!!!!thanks
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
  2. #32
    Mar 2006
    Please, can somebody explain how to control a list (playlist, browser,...) in flash?
    Thanks!
  3. #33
    Maximum Bitrate DiNASTY's Avatar
    Mar 2005
    Concord, California
    Have a look at CdR's RAD skin thread, he has posted the playlist code on the first post. If you have any questions about the code I may be able to help.
    Beer is proof that God loves us and wants us to be happy Benjamin Franklin
  4. #34
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    here's another flash question...
    I understand how labels work in flash. How do indicators work?
    Live mp3Car Facebook Chat
  5. #35
    Mar 2005
    Concord, California
    They don't... hehe.
    Actually, I know that the ONLINE indicator somehow sends a variable to flash (ON/OFF), but I don't think any others work like that. It would be nice to have some way to poll the state of an indicator with flash or have RR send out a boolean variable or something. The SHUFFLE indicator for instance would be a very important one as there is no "SHUFFLE-STATUS" label for flash integration that I'm aware of.
    -DiNASTY
  6. #36
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Code:
    onFrame (1) {
        if (_root.MASTERMUTE == "ON") {
            _root.mute.gotoAndStop(2);
        } else {
            _root.mute.gotoAndStop(1);
        if (_root.SHUFFLE == "ON") {
            _root.shuf.gotoAndStop(2);
        } else {
            _root.shuf.gotoAndStop(1);
        if (_root.STATUS <> "PLAY") {
            _root.pb = "4";
        } else {
            _root.pb = ";";
    onFrame (5) {
        gotoAndPlay(1);
    just like that :-)
    remember you must have the indicators i your .skin file also
  7. #37
    Woodbridge, VA
    Blog Entries
    55
    thanks for the info. I've tried it your way CDR with some phoco and a custom indicator (used your "mastermute" example from the RAD SWI) but it didnt work the same way mastermute does. It would definitely be nice if rr sent indicator status to flash the same way it sends labels
  8. #38
    Feb 2004
    Manchester
    it does as far as I know.. every indicator I've tried sets the same name variable in flash.. the ONLINE one works as well as I'm using that in the latest freedom. Which ones are you having problems with ? Also you could try using CUSTOMIND as well with SETIND I think.. let me know what your trying to do and I will come up with a answer.
    CdR
  9. #39
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by CdRsKuLL View Post
    CdR
    Code:
    if (_root.SMS_ARRIVED_PHOCO == "ON") {
            _root.SMS.gotoAndPlay(2);
    pasted from my .swi. Supposed to run the SMS sprite when the sms indicator is on.
  10. #40
    Feb 2004
    Manchester
    have you put the indicator in the .skin file ie..
    I,0,0,0,0,"SMS_ARRIVED_PHOCO"
    also have you just added a simple dynamic text to the flash just to see what this variable is displaying ?
    anotherwork around might be to create a new variable and send a fscommand to set this up.. ie.
    fscommand("SETVARBYCODE;PHONESMS;SMS_ARRIVED_PHOCO ","")
    you would need to stick this on a timer, and also the monitor PHONESMS .. not tested mind you, but it might work.
    CdR
  1. Flash Skin .Fla help with commands
    By neon_eddy in forum Road Runner
    Last Post: 07-18-2008, 06:18 PM
  2. Full Flash Skin
    By camsgs3 in forum Road Runner
    Last Post: 01-04-2006, 07:40 PM
  3. flash skin preview
    By holistic in forum RR Skins
    Last Post: 07-09-2005, 05:17 AM
  4. New Skin - Spaced_Out for FrodoPlayer 1.08
    By WeeZyFellA in forum FrodoPlayer
    Last Post: 10-17-2004, 10:50 PM
  5. v.3 SKIN
    Last Post: 10-15-2004, 09:29 PM
