Page 5 of 5 FirstFirst 12345
Results 41 to 50 of 50
Thread: Flash Skin Tutorial?
  1. #41
    May 2005
    Sorry for reviving an old thread. Am new to SWiSHmax flash coding hopefully some experts here can provide an answer...
    How do i convert the ALBUMART label from RR from single to double backslash?
    For example, RR gives "C:\XYZ\album_art.jpg" to the flash. However, in order for flash to load it, it needs C:\\XYZ\\album_art.jpg
  2. #42
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    you dont need to convert the label(at least i dont). Just use the album art label within your movie like so
    Code:
    loadMovie(_root.albumart)
    because the data is saved in a variable there's no conversion needed. Make sure you have the ALBUMART label in your .skin file.
    Live mp3Car Facebook Chat
  3. #43
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    ok i might aswell post this here...for Cdr to answer it
    has anyone succeded in creating a song position slider in flash.. to enighten me
    EDIT: ...for Cdr to answer it, OR Sonicxtasy02 if he is not too busy..
    (hope that fixes it)
  4. #44
    Woodbridge, VA
    Blog Entries
    55
    i've got a working one in my skin.. but because u asked CDr i'm not answering
  5. #45
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    I slider is quite easy to do.. what you need it a couple of things.. the total track time and the current track time. You then need a sprite going from frame 1 (1%) to frame 100 (100%).. then you just find out what percentage the track is upto and set the sprite accordingly..
    its no good without examples os here you go....
    Code:
    onFrame (1) {
            totalsec = _root.TRACKTIME.split(":");
            ts = int((totalsec[0] * 60)) + int(totalsec[1]);
            current = _root.CURRENTTRACKTIME.split(":");
            ct = int((current[0] * 60)) + int(current[1]);
            _root.AUDIO.Songpos.gotoAndStop(Math.round((ct / ts ) * 100));
    onFrame (10) {
        gotoAndPlay(1);
    The above it on a 20 FPS Movie, so it checks twice a second.
    hope this helps :-)
    CdR
  6. #46
    Apr 2006
    Greece
    that is perfect cdr, thanks.
    Sonicxtasy02, i edited my post just for u
  7. #47
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Bump.... its worth making this a sticky... some good info in here....
    Terran
  8. #48
    Apr 2007
    Hello, I try to load a song position bar, but iīm canīt. I use SwhisMax. CDR was posted a code, but this is the result. Can you help me, please? Excuse my poor english. thank you.
    Attached Files Attached Files
  9. #49
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Here you go. Try this one.
  10. #50
    Apr 2007
    Thanks, MCG for your reply. The problem is when the bar stop in the percentage of track. Donīt stop!! Flash reply one time... and start again from 1st frame to 101 (infinite). If I order to bar stop in frame, donīt stop. Thank you (my english is horrible, hehe)
  1. Flash Skin .Fla help with commands
    By neon_eddy in forum Road Runner
    Last Post: 07-18-2008, 06:18 PM
  2. Full Flash Skin
    By camsgs3 in forum Road Runner
    Last Post: 01-04-2006, 07:40 PM
  3. flash skin preview
    By holistic in forum RR Skins
    Last Post: 07-09-2005, 05:17 AM
  4. New Skin - Spaced_Out for FrodoPlayer 1.08
    By WeeZyFellA in forum FrodoPlayer
    Last Post: 10-17-2004, 10:50 PM
  5. v.3 SKIN
    Last Post: 10-15-2004, 09:29 PM
