I have a problem whith embedding garonav skin.
when I open gps, rr opens garonav and its not embedded. the mauri skin fills the hole display. how I can embed garonav?
Printable View
You have setting Garonav for default GPS in RRConfig. utility?Quote:
Originally Posted by chevyunger
If no,write:
GPS:External
GPS Path:C:\Programmi\GaroNav\GaroNav.exe (Edit:write your path of GaroNav folder in your System)
GPS Winodw Name:GaroNav
Edit:you use my skin of RR?
Mauri
thanks mauri,
the problem was the window name, which I dont change from last test with freedrive.
yes, I use your skin. I like it, but I have to expand it with a phoco and rearcam skin. I will use the aerea around the menu-button for some invisible buttons.
Very small update for my skin, read and download in the first post of this thread.
Mauri
Cool man! You added a gamma control, nice. Kepp it up, very nice skin indeed. Im gonna try and make a XM skin for this one also. Anychance i could get your photoshop files? Or which program did you use to make the skins?
I don't have the psd file for Photoshop.Quote:
Originally Posted by nameeri
I use one mix of 3 sw for make my skin....sorry!
But, if you want make one XM skin, is it possible sent to you the base of my Player radio without writings, .jpg.
Mauri
Mauri, first I want to say that I just love your skin :) Keep up the good work :nw:
But I have a question / request.
Is it possible to see the Album cover instead of the Windows Visual??
Second question;
How can I make the equalizer to work. If I choose one of the buttons nothing happens .
and last
I tried to change the color of the buttons from blue to amber but I had no luck. Tried everything inside Photshop CS , but can change them. Maybee that you can do this for us :o
Yes.Quote:
Originally Posted by seninha
Replace with the zip file in the bottom...
Launch the player audio,the playlist work the same, and the same AVS.
But if you search with the browser one folder with song and file .jpg of the album image,automatically appears the image.
If click in the AVS button switch to AVS.
For return in the original mode,browse the total playlist, and select with "+" big round button.
EDIT:in the Album view mode, you DON'T see the list of song of the album/folder,but ONLY the image in the area,the title of the song displayed in the display area,and UP and Down button jump in the songs of the album.
Select one song in the full playlist, and return in the original view mode....
Test if work.
Second question;
Work!
Click in the + and - button , and switch in the button,slider etc..
Select one, and with + and - move the sliders or other.
EDIT:the +,-,Up and Down button,in Mixer function, don't have the _ON and _DOWN working,you dont' see anything,but work correctly!
For use the button of PRESET, read the Readme/ Skin Command by Guino in RR folder.
>and last
With Photoshpop is it possible change the color of all,see my screenshot posted for exsample,but I don't have time to make this.....
Mauri
Mauri, as promised, i made an XM skin. I have not tested this yet as i am still waiting for my XM reciever, but I think it should work just fine. For now, I will just post the XM_OFF.jpg so that You can see what I have done. Some of the XM buttons are just text (im not that good at illustrating :) ) but ive tried to keep the look overall the same.
After I have tested the skin when I have my XM reciever, I will post all the files here.
I have make this .... _OFF file.
Possible to use the SCAN Mode
If you want the _OFF,_ON,and _DOWM, PM me your e-mail, and sent all files to you.
EDIT:for the .skin...this is your job! :)
If work ok, upload the files for update my skin for all.
Mauri
