Wrong forum
Hello group
Does any have any suggestions as to why my divx movies play perfect at 60% cpu when using winamp 2.95 but will not play smooth ( 100% cpu use) using either of the player in RR , WMP 10 or Frodo's built in player. I'm useing klite filter pac.
I should mention that this happened on my nlited version of windows. Everything is ok on a normal full install on the same machine. Obviously something was removed that is causing an issue with divx playback. shooting in the dark in hopes someone experienced the same phenomena. thanks
Wrong forum
1997 Mustang GTS "Jenna"
VIA SP13000, 7" Xenarc TSV, 200GB, 'modified' M2-ATX, 1GB DDR400/3200, BU-353. RoadRunner + LSXVoid
