Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
Thread: 4WD Skin
  1. #11
    Constant Bitrate ashgrovered's Avatar
    Jul 2005
    Brisbane Australia
    I don’t want to release the skin until I have finished it, but I have zipped up the traffic skin and scripts so you can have a bit of a play.
    Because some of the paths are hard coded in the autoscript files you will have to unzip the 4WD directory under C:\Program Files\Road Runner\SKINS (Iwill fix this later)
    The source file for the autoit .exe are provided as well
    The menu skin is just a 2 button skin one to call the traffic skin and the other to exit RR so you can have a play.
    On the Traffic skin the auto refresh button starts the auto update from the web, I cant get the switch button command to then stop the auto update so after you start auto update it will continue to run just end the task.
    If you have any suggestions on how to make it better I would be interested.
    Because I am spending all my time working on the skin I don’t have time to do any instructions
    EDIT: Link removed
  2. #12
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    Thanks for that. Much appreciated. I look forward to the finished skin
  3. #13
    Jul 2005
    Brisbane Australia
    I have just done the FreeDrive screen and one menu, I might have to spend some time finding a good LCD font I am not really happy with the one I am using. Also I will probably change the fancy Menu font back to the Arial which is what I used on the first screens; I don’t want to have 2 different fonts.
    Any comments…..
    The FD screen
    The FD Menu
  4. #14
    Jul 2005
    Brisbane Australia
    I see a few members have DL the traffic.zip
    I worked out what the problem with starting and stopping auto update.
    Have a look in Traffic.skin
    Change both the 2 occurrences of SWITCHBUTTON;7
    To SWITCHBUTTON;8
    It is a shame it took this long only to find out I cant count.
  5. #15
    May 2004
    Oziexplorer
    Has anyone solved the above issues with ozi?
    Did you get it to embed properly?
  6. #16
    Jul 2005
    Brisbane Australia
    Quote Originally Posted by dukman
    I have it working quite well with skinbedder, and map the main ozi commands I need to function keys (all part of Ozi), and then just get the button on my RR skin to call the function key
    I also did a killozi Autoit script to kill the ozi task if required
    There is a bit of OziExplorer discussion here
    Embedding app with dialogs?
  7. #17
    Nov 2005
    Missouri
    Quote Originally Posted by ashgrovered
    I hadn’t planned to release the skin until it was completed; I still have to do the following:
    Skin for freedrive
    Embed and skin OziExplorer
    Work out how to get compass to start stop
    Order my temperature probe and get the min/max working
    Thinking about it I still have a long way to go
    Are you interested I the 4WD skin or just the scripts for the traffic stuff so you can use them in one of your skins
    Are you still working on this? I'd like to try it out.
  8. #18
    Jul 2005
    Brisbane Australia
    Progress
    I have sent a PSD file to Tissy to make me a compass for the LCD in Flash so I don’t have to use compass.exe.
    Should get that back from him soon.
    But most of my time has been doing 2 FreeDrive skins to match the brushed aluminium and brushed metal RR skins
  9. #19
    Low Bitrate happpyg's Avatar
    Feb 2005
    Bunbury, Western Australia
    If you can use it here is a link to a simple compass I made up after reading how it's done on these forums & then playing in swishmax for a while and some screenshots of it in action. I am sure there is a better way to do what i've done but i've never designed anything in flash before & it works ok for me.
    Compass (SWF) http://www.happyg.mine.nu/carpc/compass.swf
    Original in Swishmax : http://www.happyg.mine.nu/carpc/compass.swi
    Some screenshots of it running in the Triton skin I am using at the moment:
    Semperon 3200+/512MB/ Seagate SATA2 120GB
    10.2" Xenarc/ Netgear USB Wireless
    M2-ATX/RadioShark
    BU-353 GPS Receiver
    http://www.happyg.mine.nu/carpc/index.html
  10. #20
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by meddler
    Any chance for a link to the skin? I am very impressed especially with the links to the traffic cams. Excellent work ashgrovered.
    AshG - Just putting my name down for the Traffic Cam app... I'd be happy to have a quick look as I'm up on Autoit scripts plus I have a sumular need but for traffic maps from the web.
    Currently I use Mobileweb but that seems quite good for skining and intergration with RR.
    Terran
  1. RR Web Cam Skin Help
    By babyface in forum Road Runner
    Last Post: 05-20-2013, 03:47 AM
  2. New skin
    By Floatingpi in forum CF Skins
    Last Post: 12-22-2007, 12:31 PM
  3. Red highlights for BMV2 Skin done
    By Mad Ad in forum RR Skins
    Last Post: 10-17-2006, 12:41 PM
  4. Skullster Skin.. Please help me finish this skin
    By CdRsKuLL in forum RR Skins
    Last Post: 08-05-2005, 08:37 PM
  5. finnaly skin uploaded
    By liquid_smoke in forum ME Archive
    Last Post: 12-31-2003, 09:13 PM
