Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 42
Thread: IG Nag screen/ embed issues FIX how to
  1. #11
    Dec 2005
    Um, this is going to sound really stupid, but how do I run a program using this flag? Where do I enter it in?
  2. #12
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    if you are using just windows you add the flag to a shortcut for the application. Rightclick the shortcut>properties>Target field = "C:\Program Files\iNav\iGuidance.exe" nowarning
    using a button in RR the code for the button would be
    RUN; "C:\Program Files\iNav\iGuidance.exe|nowarning"
    using skinbedder, it uses autoIT to launch IG so you will have to edit the startup.au3 file found in the skinbedder dir (you will also need to install AutoIT3 to recompile the script to a .exe)
    edit startup.au3 and edit the line
    Run("C:\Program Files\iNav\iGuidance\iGuidance.exe nowarning", "C:\Program Files\iNav\iGuidance")
    to look like above.
    beer replenishment fund
    mp3car live search
  3. #13
    Variable Bitrate Tissy's Avatar
    Sep 2005
    Essex, United Kingdom
    I may be being a bit thick here, but what should the entry look like when using RR Config utility. I have tried the above combinations, but the nag screen still pops up. Any ideas?
    It works from Windows though.
    Many thanks,
    Steve
    System - Epia SP13000 for Main PC, Holux GR-213 USB GPS Receiver SiRF Star III, 2.4Ghz Uplink with VNC and Custom designed USB Intelligent SDC (In DEV). All fed to a Sony CDX-F7500 Headunit via USB. www.wrx-carpc.co.uk
  4. #14
    Sep 2005
    Cancel my last, i think i have done it.
    In the RR Config program, it need to be in quotes, so the entry should be something like:
    "C:\Program Files\iNav\iGuidance Europe\iGuidance.exe nowarning"
    Steve
  5. #15
    Sep 2005
    I do have this other annoyance though, any ideas why the Windows bar pops up when i click on the 3D button?
    What could the possible causes be.
    Cheers,
    Steve
  6. #16
    Constant Bitrate 2 STanGeR's Avatar
    Aug 2005
    Terre Haute, IN
    What about the nag for when it doesn't detect a GPS receiver? Is there a work around for this too?
  7. #17
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by 2 STanGeR
    Yes, just pull our your credit card / cash everytime the "no GPS receiver found" pop up.
    Seriously, if that's an error you get everytime the program start up, there is some config problem you gota fix.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  8. #18
    Aug 2005
    Terre Haute, IN
    Well, whenever my system came out of Hibernation, it would throw up the error because the GPS hadn't had time to reconnect to the Sats. I also get this error whenever I am doing some testing on one of my systems because I don't have an extra GPS unit to plug in. It is just a nag, but I thought somebody else might have a work around too.
  9. #19
    Jan 2004
    NYC
    Quote Originally Posted by DiNASTY
    EDIT: I think it's time for an iGuidance subforum
    Yea tell me about it, ive been saying this since Nov.http://www.mp3car.com/vbulletin/gps/63755-iguidance-sub-forum-post702748.html
    and others have too.. http://www.mp3car.com/vbulletin/mp3car-forum-suggestions-comments/65914-iguidance-sub-forum-request.html#post702744
    I also had no clue u can do this in IG
  10. #20
    Aug 2003
    Chicago
    Quote Originally Posted by Tissy
    Cheers,
    Steve
    you could just have RR hide the taskbar
    mp3car live search
  1. I know the problem but dnt know how to fix it?
    By corsamel in forum General Hardware Discussion
    Last Post: 08-18-2003, 12:11 PM
  2. Datalux touch screen issues
    By infx708 in forum LCD/Display
    Last Post: 11-06-2002, 05:23 PM
  3. What's wrong with my screen and how can i fix it?
    By Euclid in forum LCD/Display
    Last Post: 11-04-2002, 11:41 PM
  4. allens controller and denis k screen issues
    By kardas in forum LCD/Display
    Last Post: 10-12-2002, 08:41 PM
  5. X-MP3Pad: Beta testers needed... Please read!
    By PorscheMP3 in forum Software & Software Development
    Last Post: 08-22-2002, 12:55 PM
