Results 1 to 7 of 7
Thread: Skinning Help
    Constant Bitrate mick0uziel's Avatar
    Feb 2005
    ca
    Skinning Help
    Hi, I tried reading the tutorial and topics, its either it did not sink in or i did not find the answer. for example, the alpine skin, how do i direct the picture viewer button to point to a specific directory? or the games button, how do i direct it when pressed to go to a specific directory or run an application? and what if i dont want the word games in there and i want to replace to like obd-ii, how do i change it and point it to the right application? please help. thanks
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
    Constant Bitrate Gixxer's Avatar
    Jun 2005
    Daphne, Alabama
    I use the "LOAD" command.
    example:
    Make a skin for the app You would like to run. ( say, OBDII.skin)
    Should include OBDII_OFF.jpg, OBDII_ON.jpg, OBDII_DOWN.jpg, OBDII_EMPTY.jpg. (atleast the OFF.jpg and ON.jpg)
    Then assign a button on the Menu to perform that function.
    B,523,418,151,56,"LOAD;OBDII.skin",
    You can also use the "LAUNCH" command. But this is how I usually do it.
    Hope that helps.
    Low Bitrate pwcmed's Avatar
    Jul 2005
    San Antonio, TX
    The best thing I found that helps with most of my skinning questions is looking at other skins or learning what to search for.
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    I dont do much skinning but when i need small changes i do
    Jun 2005
    Daphne, Alabama
    Quote Originally Posted by pwcmed
    True, You can just open a .skin file in notepad and see how it is constructed.
    Feb 2005
    ca
    thanks for the reply, where i get lost is, where is the language that instructs the skin to open the particular program, say the obd program, shouldnt there be a path like crogram files.... to direct the button? thanks again for the help
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
    Jun 2005
    Daphne, Alabama
    In that case it should look something like this
    B,638,139,160,44,"RUN;C:\Program Files\Road Runner\CDRIP\CDRip.exe","RipCD"
  1. Skinning .NET Applications made easy
    By zorro in forum Coders Corner
    Last Post: 12-29-2005, 10:16 AM
  2. Skinning tutorial?
    By erazor in forum FrodoPlayer
    Last Post: 11-06-2004, 08:36 AM
  3. Skinning Questions with VB6
    By (6) in forum Software & Software Development
    Last Post: 10-19-2004, 03:05 PM
  4. Is skinning FP as easy as Winamp ??
    By Don 944 LA in forum FrodoPlayer
    Last Post: 09-27-2004, 10:52 AM
