Page 5 of 5 FirstFirst 12345
Results 41 to 49 of 49
Thread: Skin Release "RAD" Beta 1 Flash Based
  1. #41
    Maximum Bitrate pyros's Avatar
    Mar 2004
    Toronto, Canada
    Thanks CdR.. I'll take a look at it!
    I didn't realize you did your stuff with swishmax.. I assumed you were using Macromedia Flash or something... do you do all your (flash based) skins with swishmax?
    2004 Ford Mustang Mach 1
    Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
    Install Status: DONE
    My XM FAQ
  2. #42
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Quote Originally Posted by pyros
    yep all swishmax :-)
    CdR
  3. #43
    Mar 2004
    Toronto, Canada
    I started playing around with it... very nice work.. I can't believe how much work was put into this....
    When I'm trying to preview/play the movie in swishmax, I'm getting a TON of errors... is there anything missing or do I have something configured incorrectly? I'm getting this in the debug panel:
    Function or method 'play' doesn't have the correct number of values between the () in statement:
    pointer:n (press)
    startDraglocked(0,0,0,140);
    _root.songpos.gotoAndPlay(40);
    _root.tracktext.play(2);
    _root.letter._alpha = 100;
    _root.letter1._alpha = 100;
    _root.Dirlist.gotoAndPlay(5);
    ERROR: Cannot find variable or function 'Home' in statement:
    Scene_1:nLoad ():: 3: Home._alpha = 0
    Referenced from: "_root"
    ERROR: value on the left of the '.' is undefined for '._alpha' in statement:
    ERROR: Cannot find variable or function 'History' in statement:
    Scene_1:nLoad ():: 4: History._alpha = 0
    ERROR: Cannot find variable or function 'Address' in statement:
    Scene_1:nLoad ():: 5: Address._alpha = 0
    ERROR: Cannot find variable or function 'list' in statement:
    Scene_1:nLoad ():: 6: list._alpha = 0
    ERROR: Cannot find variable or function 'voltext' in statement:
    Scene_1.Volume:nFrame (1):: 2: if (voltext <> substring(_root.VOLUME,1,_root.VOLUME.length -1))
    Referenced from: "_root.Volume"
    ERROR: Cannot find variable or function 'length' in statement:
    Scene_1.Volume:nFrame (1):: 3: voltext = substring(_root.VOLUME,1,_root.VOLUME.length -1)
    ERROR: Cannot find variable or function 'volchange' in statement:
    Scene_1.Volume:nFrame (1):: 5: if (_root.volchange =="1")
    FSCOMMAND cmd="gesturesoff" arg=""
    LOADING URL (GET) url="colour.txt"
    window=""
    LOADING URL (GET) url="menu.txt"
    window=""
    Any insight would be greately appreciated
    Thanks,
    Chris
    My XM FAQ
  4. #44
    Feb 2004
    Manchester
    the reason for these errors is because its looking for variables from RR which its not getting, you cant really demo it in a flash player
    CdR
  5. #45
    Mar 2004
    Toronto, Canada
    Thanks CdR, shortly after posting the log that's what came to mind.... I'm going to keep hacking away at this.. it looks pretty neat. I just finished doing a bunch of swishmax tutorials so I'm getting a better grasp of how to use this thing...
    Any reading you can suggest on here on how flash interacts with RR?
    Thx,
    Chris
    EDIT: Ignore the suggested readings.. i just found the motherload
    My XM FAQ
  6. #46
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    why does it keep on saying loading on my skin
  7. #47
    Feb 2004
    Manchester
    you need to downgrade your flash from 9 to 8.. have a look on the RR forum for a thread about it
    CdR
  8. #48
    Jun 2006
    Houston, TX
    I have flash 8 I am using your MC2 skin with no problem but RAD wont load
  9. #49
    Feb 2004
    Manchester
    when you see the loading screen type "audio" including the " this will then take you to the audio screen and from there you should be able to access the others. You could also set in the rrconfig start commmand to execute - Audio (this is on the right hand side when you start rrconfig.exe up. This will auto take you to the audio screen when you start RR.
    CdR
  1. Simplistique Skin Release - download and screenshots
    By lloydy in forum RR Released Skins
    Last Post: 05-04-2013, 10:58 AM
  2. Flash based commercial front end discussion
    By DavidL in forum Other Cool Front Ends
    Last Post: 04-05-2006, 02:20 PM
  3. Next release (BETA 10) delayed
    By skippy76 in forum Road Runner
    Last Post: 11-24-2005, 10:29 PM
  4. Skin based on Vladien's Land Rover Skin
    By SpacemanSpiff in forum MediaCar
    Last Post: 01-02-2005, 12:49 PM
  5. ** New Flash Based Media Player **
    By jcraig in forum Software & Software Development
    Last Post: 08-20-2004, 10:58 AM
