Page 10 of 48 FirstFirst 1234567891011121314151617181920 ... LastLast
Results 91 to 100 of 471
Thread: New Road Runner Clocks/Logos (By Tissy)
  1. #91
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    That sounds like it to be honest,i've not set the port or correct units under Gps config,back in 5 with the answer.
  2. #92
    Nov 2005
    Midlands
    No luck mate.
    I'm using mapmonkey,my gps port in Mapmonkey and system devices is 3 so i set RR com port to 3,i also tried 03 with no joy,i'm getting nada.
  3. #93
    Maximum Bitrate DiNASTY's Avatar
    Mar 2005
    Concord, California
    On the last version of the speedo, KPH should work but with incorrect readings on the dial.
    Griff1, it sounds like it should be working... You may check if the labels you added are added to the same .skin file that the clock is in. Also, the labels don't need to be visible so you may also try:
    L,0,0,0,0,,,,,,"GPSSPD",
    L,0,0,0,0,,,,,,"GPSHDG",
    L,0,0,0,0,,,,,,"GPSSAT",
    Beer is proof that God loves us and wants us to be happy — Benjamin Franklin
  4. #94
    Nov 2005
    Midlands
    Yeah it should work but it don't seem to wanna.i've done everything suggested but to no avail.
    I made the RGB values what they are for Testing ONLY,so i can see any changes without flicking through the clock.
    The clock and the code are added to my BMV2 menu.skin.
    This is the whole menu.skin....
    MEDIACAR Skin
    MEDIACAR MainMenuSkin Skin
    menu_off.jpg,menu_off.jpg,menu_on.jpg,menu_down.jp g
    /, F, x, y, w, h, Movie name
    F,92,1,51,72,"Designed for XP.swf"
    F,37,-1,52,62,"P4.swf"
    /, I, x, y, w, h, Code;INDICATORCODES
    I03,37,63,50,9,"EXISTS;C:\connected.txt"
    /, IMG, x, y, w, h, File Name, Option;IMGLAYER
    IMG,37,63,50,9,"online_indicator.gif",ON
    IMG,37,63,50,9,"online_indicator.gif","DOWN"
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B01,10,74,369,108,"AUDIO","Audio player"
    B03,421,74,369,108,"VIDEO","Video player"
    B04,10,186,316,110,"DVD","powerdvd_player"
    B05,474,186,316,110,"RADIO",""
    B06,10,302,370,108,"LAUNCH",""
    B07,10,530,155,75,"WEB",""
    B08,420,302,370,108,"GPS","GPS"
    B09,12,417,145,107,"PHOCO",""
    B10,160,430,65,85,"MUTE","Mute"
    B11,226,430,63,85,"VOL-","Volume-"
    B12,515,430,63,85,"VOL+","Volume+"
    B13,581,430,61,85,"MIXER","Mixer settings"
    B14,643,417,145,107,"TV",""
    B15,165,530,156,75,"GAMMA","Gamma mode"
    B16,322,530,156,75,"WEATHER","Weather"
    B18,478,530,156,75,"MINIMIZE",""
    B19,633,530,156,75,"EXIT","Exit"
    /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
    S01,290,466,223,35,290,466,223,35,H,01,"POINTER2.g if",013,"MASTER","Master"
    I01,185,455,30,35,"MUTE:b"
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L00,415,442,50,25,255,255,255,13,"Arial Narrow:B","VOLUME","Volume"
    L01,696,13,85,30,255,255,255,18,"Arial Narrow:B","TIME","Time"
    L02,699,41,87,30,255,255,255,18,"Arial Narrow:B","DATE",""
    F01,319,139,162,205,"clock.swf"
    L,632,4,56,20,0,0,0,12,"Arial","GPSSPD","CENTER"
    L,614,27,73,20,0,0,0,10,"Arial","GPSHDG","CE NTER"
    L,626,49,62,21,0,0,0,14,"Arial","GPSSAT","CE NTER"
    END
    Maybe i'm going blind,any1 see a mistake?
  5. #95
    Variable Bitrate Tissy's Avatar
    Sep 2005
    Essex, United Kingdom
    Quote Originally Posted by DiNASTY
    Well done mate, i knew there must be a way to make them not visible !!
    I'm working on new dial markings to take KPH.
    Cheers,
    Steve
    System - Epia SP13000 for Main PC, Holux GR-213 USB GPS Receiver SiRF Star III, 2.4Ghz Uplink with VNC and Custom designed USB Intelligent SDC (In DEV). All fed to a Sony CDX-F7500 Headunit via USB. www.wrx-carpc.co.uk
  6. #96
    Nov 2005
    Midlands
    Does this require the latest RR?
  7. #97
    Nov 2005
    Midlands
    This is my RR.ini file.
    Ok,i've noticed something...the RR version in the car is 19.02.06 and the RR.ini says Mappointport=3,
    the RR version on my Desktop is 02.05.06 and the RR.ini says GPSport=3.....could that be it?
    Attached Files Attached Files
  8. #98
    Aug 2005
    Athens,Greece
    Quote Originally Posted by Griff1
    Hi there!
    Should CE NTER be spelled as CENTER? No space that is..
    Did this in my skin and it works as a charm!
  9. #99
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by Tissy
    DarquePervert - The Toyota one being refered was on my site, it has now been removed as it was just the logo, clock and speedo. They are being updated slowly with the addition of the compass screen.
    When can we have the Toyota back?
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  10. #100
    Variable Bitrate xs10x's Avatar
    Jul 2005
    Bronx, NY
    sdujolo - Not a major problem, it was just make my life a bit easier, i will do it with the Audi and Quatro logos. What colour do you want the background to the logo front. Silver / chrome as it is, or another colour.
    xs10x - The new Chevy one has been uploaded, let me know if everything is OK with it. I've changed a couple of fonts to white to show you how they look. See if you prefer the blue or the white (or if you like it as it is). If you need any changes then i weill just upload them.
    Regards,
    Steve
    Everything looks and works great. Just need all the Clock numbers (seconds and the 12,3,6,9) to be white to match the rest of the features. Also, The blue displays on the clock and speedo to be white like the compass. Looks great with the Blue Alpine skin.
    `¨`¨`¨`¨` _____||¯.\__
    .:.:.:.:.:.:;!_(o)______(o)'i
    TruckputerX - Vortech SuperCharger Vid
    TruckputerX Progress Bar [|||||||||-] 90% Complete [It's never 100% done]
  1. Road RUnner and Navi Voice
    By cdevelasco in forum PowerVoice
    Last Post: 07-20-2007, 01:40 PM
  2. Road runner Ideas (BIG LIST)
    By sephiroth7 in forum Road Runner
    Last Post: 04-01-2007, 10:50 AM
  3. Road Runner Sound Problem
    By Mick300ZX in forum Newbie
    Last Post: 05-23-2006, 08:45 PM
  4. Can I watch video into a Road runner ?
    By shinjetko in forum RR Bug Tracker
    Last Post: 05-19-2006, 01:31 AM
  5. Road Runner Facts...
    By guino in forum Road Runner
    Last Post: 02-21-2005, 12:16 PM
