Page 34 of 48 FirstFirst ... 242526272829303132333435363738394041424344 ... LastLast
Results 331 to 340 of 471
Thread: New Road Runner Clocks/Logos (By Tissy)
  1. #331
    Nov 2005
    FL
    also does anyone know what that little egg shaped thing at the corner of my screen it?
    CLICK ME FOR BMW CARPUTERS
    95 Avus M3
    Mods: ;-)
    Carputer: Lilliput 619, GPS= LT-20 Receiver, IGuidance 3 & Streets & Atlas 2K6, RR Front End, Removable Dell Inspiron Laptop, More to come........
  2. #332
  3. #333
    Variable Bitrate Tissy's Avatar
    Sep 2005
    Essex, United Kingdom
    Can i just confirm a couple of bits.
    • Are all the files you have shown me in the skin folder of the skin you are using?
    • I personally change the default name of the SWF file to logo.swf
    • Then in the menu.skin file you should see a line similar too -
      /, F, x, y, w, h, Movie name
      F01,274,133,252,332,"logo.swf"
    • Latest flash installed, prefereably version 8, if you are running version 9, and this still doesn't work, please let me know and i will send you a modified version of the SWF file.
    Hope this helps.
    System - Epia SP13000 for Main PC, Holux GR-213 USB GPS Receiver SiRF Star III, 2.4Ghz Uplink with VNC and Custom designed USB Intelligent SDC (In DEV). All fed to a Sony CDX-F7500 Headunit via USB. www.wrx-carpc.co.uk
  4. #334
    Nov 2005
    FL
    I must be annoying you since i cannot figure this out. At least this might help someone else.
    I copied all the files and placed them in my tester skin. i changed the name of MPH Clock, Speedo & Compass (smooth).swf to logo.swf.
    my line in cfx tester reads:
    /******************* BIG NOTE ********************
    / To keep the same look for the main menu and the extra menu, MAKE SURE THE FOLLOWING SECTION IS COPIED OVER TO menu2.skin.
    /***************** END BIG NOTE ******************
    /******************* Dinasty's Flash Clock/Logo version - *******************
    /Uncomment IMG and F01 tags to show Flash Clock/Logo - The IMG is needed for the "pushed" background
    /Also comment out RR_logo in the next section
    IMG,382,158,166,166,"car_logo.jpg"
    F01,391,165,149,149,"logo.swf"
    /***************** END Dinasty's Flash Clock/Logo version - *****************
    /******************* Road Runner Logo version - *************************
    /Uncomment tag to show RR logo (Comment out car_logo and clock.swf above)
    /IMG,158,200,620,98,"RR_logo.jpg"
    /***************** END Road Runner Logo version - ***********************
    END
    I have the flash 8 renamed to flash 9.
    I also dont understand how does the main file "mph clock...." know which files to play when clicked.
    thanks
    95 Avus M3
    Mods: ;-)
  5. #335
    Nov 2005
    FL
    i have also tried to view the swf files that i dl'd from your site and i cannot even view them in firefox, where as i can view other swf files.
    95 Avus M3
    Mods: ;-)
  6. #336
    Sep 2005
    bimmeracer - Don't worry mate, we WILL get this working. Are you on MSN, that way we can do some live testing and it makes it easier sending files back and forth. If so, please email me and i'll give you my MSN ID or you can pass me yours.
    Steve
  7. #337
    Jun 2002
    Malaysia
    Hi Tissy, can you take a look at mine?
    This is my menu.skin
    Code:
    IMG01,697,23,80,70,"MM_NotActive.jpg","OFF"
    /, I, x, y, w, h, Code;INDICATORCODES
    I01,19,23,80,70,"HEADING"
    I02,115,23,22,38,"PHONE_CONNECTED_PHOCO"
    I03,144,26,24,30,"MISSED_CALL_PHOCO"
    I04,174,26,30,30,"SMS_ARRIVED_PHOCO:b"
    I05,639,22,45,39,"ONLINE"
    I06,697,23,80,70,"DIRECTION"
    I07,150,452,20,20,"MUTE:b"
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B01,6,132,346,101,"AUDIO",""
    B02,352,132,97,62,"CDRIP",""
    B03,449,132,347,101,"VIDEO",""
    B04,6,233,319,101,"RADIO",""
    B05,477,233,319,101,"DVD",""
    B06,6,333,346,101,"PHOCO",""
    B07,352,372,97,62,"WEB",""
    B08,449,333,347,101,"GPS",""
    B09,5,434,95,101,"WEATHER",""
    B10,114,440,74,87,"MUTE",""
    B11,189,440,74,87,"VOL-",""
    B12,538,440,74,87,"VOL+",""
    B13,613,440,74,87,"MIXER",""
    B14,701,434,95,101,"LOAD;TRIPMETER.SKIN","TRIPMETER"
    B15,5,535,152,61,"CAMERA",""
    B16,164,535,152,61,"GAMMA",""
    B17,324,535,152,61,"LAUNCH",""
    B18,484,535,152,61,"SKIN",""
    B19,644,535,152,61,"MINIMIZE",""
    F01,291,123,218,233,"logo.swf"
    /, Y,  Back Slider file path
    Y01,"SLIDER_VOLUME\slider_*.gif"
    /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
    S01,277,493,247,25,278,493,247,25,H,01,"",0,"MASTER",""
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L01,32,100,45,18,255,120,0,18,"Ericsson GA628","GPSHDG","RIGHT"
    L02,693,100,89,18,255,120,0,18,"Ericsson GA628","CUSTOMFDNEXTMANDIST","RIGHT"
    L03,78,95,13,16,255,120,0,16,"Ericsson GA628","=o",""
    L04,225,29,160,24,255,120,0,24,"Ericsson GA628","TIME","LEFT"
    L05,419,29,200,24,255,120,0,24,"Ericsson GA628","DATE","RIGHT"
    L06,117,63,562,24,255,120,0,24,"Ericsson GA628","CUSTOMFDROAD","SCROLL-CENTER"
    L07,117,96,562,24,255,120,0,24,"Ericsson GA628","TRACKNAME>>tagtitle","SCROLL-CENTER"
    L08,424,459,72,21,255,120,0,22,"Ericsson GA628","VOLUME","LEFT"
    END
    This is the link to the skin in zip format
    http://www.nusantech.com/FileUpload/BMWE36.zip
  8. #338
    Sep 2005
    Looks very nice masch, but if means nothing if you don't tell me what the problem is !!
    You need to explain what the problem is fully and more importantly what version of flash you are using. Also screen dumps help, a picture tells a thousand words.
    Regards,
    Steve
  9. #339
    Jun 2002
    Malaysia
    Oops, sorry. I already mentioned the problem in page 21
    I'm using flash player 9, and I dont see the clock anywhere.
  10. #340
    Nov 2004
    UK
    Hey Tissy - any plans to release a version with a transparent clock face (instead of the dark grey) so I can match the colour to my speedo dials?
    Ian
  1. Road RUnner and Navi Voice
    By cdevelasco in forum PowerVoice
    Last Post: 07-20-2007, 12:40 PM
  2. Road runner Ideas (BIG LIST)
    By sephiroth7 in forum Road Runner
    Last Post: 04-01-2007, 09:50 AM
  3. Road Runner Sound Problem
    By Mick300ZX in forum Newbie
    Last Post: 05-23-2006, 07:45 PM
  4. Can I watch video into a Road runner ?
    By shinjetko in forum RR Bug Tracker
    Last Post: 05-19-2006, 12:31 AM
  5. Road Runner Facts...
    By guino in forum Road Runner
    Last Post: 02-21-2005, 11:16 AM
