Page 39 of 48 FirstFirst ... 2930313233343536373839404142434445464748 LastLast
Results 381 to 390 of 471
Thread: New Road Runner Clocks/Logos (By Tissy)
  1. #381
    Variable Bitrate Tissy's Avatar
    Sep 2005
    Essex, United Kingdom
    turbobob9242 - My God, i can't believe i missed out a Porsche logo !!
    It shall be on my site by the end of the day mate.
    ivanmx6 - I still haven't received your email address so you can test a version for me mate to see if it cures your issue.
    Out of interest, for those that find flash objects a bit sluggish on their CarPcs, i have found that if you turn down (or indeed turn off) the 'Hardware Acceleration' under the advanced properties of your video driver, this greatly improves the performance of flash and these clocks.
    System - Epia SP13000 for Main PC, Holux GR-213 USB GPS Receiver SiRF Star III, 2.4Ghz Uplink with VNC and Custom designed USB Intelligent SDC (In DEV). All fed to a Sony CDX-F7500 Headunit via USB. www.wrx-carpc.co.uk
  2. #382
    Constant Bitrate ivanmx6's Avatar
    Dec 2006
    Dorset, UK
    Sorry Tissy, been busy finishing off the install in the car.
    (And you're more than welcome.)
    You have PM mate.
    PS. Took the car for it's first "CarPC enabled" run today to see if everything worked.
    Looks like the compass isn't doing it's stuff either.
    Apart from that everything's fine.
    PPS. Made a couple of changes (non clock related) and took the car for another spin today. Strangely, the Compass,Alt and Sat indicators are all now working... Weird!!
  3. #383
    Sep 2005
    turbobob9242 - Porsche logo uploaded onto my site, hope you like it and its the logo you wanted. If you have a custom one, just let me know.
    ivanmx6 - You have email and PM Ken .
  4. #384
    Dec 2006
    Dorset, UK
    Thanks Tissy - all sorted now.
  5. #385
    Constant Bitrate Paul C's Avatar
    May 2004
    West Sussex
    I've just installed the clocks into my skin and they are most excellent thank you for a brilliant piece of software.
    But I have a problem on the odd occasion when I go to use my GPS software (Freedrive) it closes RR I am using or tried both xport3 and GPSgate. These little apps did solve one problem of not having any readings on the compass and speedo etc. As rr shuts an error box does come up but its so quick I don't get to see what it says.
    Is this a setting I've missed? hope somebody can help me please
  6. #386
    Sep 2005
    Hello Paul,
    West Sussex, mmm, getting closer and closer to me all the time !!
    Was everything working OK before you installed the clocks, or is it all a relatively new build ?
    What skin are you using for Road Runner ?
    Does everything work how it should, before you enter into FreeDrive ?
    Thing is with these problems, it could be any number of things, so you need to post as much detail as possible.
    Also, if you look in the RR, your skin and the FreeDrive directories, sometimes there is a debug.txt file or similar. This may contain what is causing the specific error.
    Hope that helps.
    Regards,
    Steve
  7. #387
    May 2004
    West Sussex
    Quote Originally Posted by Tissy View Post
    Hello Paul,
    Hope that helps.
    Regards,
    Steve
    yep west sussex not to far to send the lads round if we can't sort this
    I have just installed the clocks so its all new to me
    The skin I am using is my own
    Yes every thing works as it should before you enter freedrive. I do get the warnings for speed cameras etc. Sometimes I can get into freedrive and its fine another it closes RR. The only thing I will ask about this is when you switch to the compass it doesn't do anything until you move is this right?
    Thanks for your help on this
  8. #388
    May 2004
    West Sussex
    Just a little up date on this, on the way home from work last night I went into the GPS screen and back out many times and it worked fine. The only difference between now and when I had the problem is that the computer is not connected to the network but I cant think its that. The other thing thats different is I had Timbuktu running so I could do some adjustments would this cause an error do you think?
  9. #389
    Dec 2006
    Dorset, UK
    Quote Originally Posted by Paul C View Post
    Mine's the same. It was a bit disconcerting at first because the dial moves around the needle rather than the needle moving round the dial.
    Hmm. Sussex lad eh? Been on SMCC lately?
  10. #390
    May 2004
    West Sussex
    Quote Originally Posted by ivanmx6 View Post
    sorry lost me whats SMCC?
    edit:- ok i just googled and found it so the answer is no i haven't
  1. Road RUnner and Navi Voice
    By cdevelasco in forum PowerVoice
    Last Post: 07-20-2007, 12:40 PM
  2. Road runner Ideas (BIG LIST)
    By sephiroth7 in forum Road Runner
    Last Post: 04-01-2007, 09:50 AM
  3. Road Runner Sound Problem
    By Mick300ZX in forum Newbie
    Last Post: 05-23-2006, 07:45 PM
  4. Can I watch video into a Road runner ?
    By shinjetko in forum RR Bug Tracker
    Last Post: 05-19-2006, 12:31 AM
  5. Road Runner Facts...
    By guino in forum Road Runner
    Last Post: 02-21-2005, 11:16 AM
