Page 41 of 48 FirstFirst ... 313233343536373839404142434445464748 LastLast
Results 401 to 410 of 471
Thread: New Road Runner Clocks/Logos (By Tissy)
  1. #401
    Variable Bitrate Tissy's Avatar
    Sep 2005
    Essex, United Kingdom
    Sorry guys, I had rearranged my web pages and pointed to the old link.
    From the main http://www.wrx-carpc.co.uk page you can go to the clocks page by following the clock logo in the centre of the screen entitled 'RR FLASH CLOCKS' or go direct to this page http://www.wrx-carpc.co.uk/clocks/rr_clocks.htm
    Sorry for the confusion, all links have been updated with the lastest logos added.
    System - Epia SP13000 for Main PC, Holux GR-213 USB GPS Receiver SiRF Star III, 2.4Ghz Uplink with VNC and Custom designed USB Intelligent SDC (In DEV). All fed to a Sony CDX-F7500 Headunit via USB. www.wrx-carpc.co.uk
  2. #402
    Feb 2007
    Tissy, I'd like to put a couple of these on one page, (Sort of a screen saver page). Is there a way to make each individual one be the first one to show up. For instance, if I put two of these on one page, and wanted to have the speedometer on one to come up and the Compass on the other to come up. Is that possible? or would they both come up as the logo on the first screen? I would really like to have an individual version of each of the speedometer, compass, and clock to appear on this screen. Sorry if that sounds confusing. Thanks -MG
  3. #403
    Sep 2005
    No, i know excatly what you want.
    I have been meaning to do it for ages for someone else.
    Over the next few days i will try and knuckly down and produce seperate files for each of the elements.
  4. #404
    Jun 2005
    Dresden, Germany
    Very nice work. The logo from Fiat is old, try a newer one
    My problem is, the swf-gauges works, but no vehicle or RR logo is displayed. The same by the mph version. What is wrong? The archive is extracted to the BMV2 main folder.
  5. #405
    Feb 2007
    The fiat logo might be old but then again someone might have an older fiat and wanted that logo. If you ask nicely, Tissy is usually pretty fast about making whatever you like. Just supply an example.
    As for the problem, depending on when you last downloaded it, i would try to re-download the whole thing and replace all your files. I was having a similar problem and that solved it (including the pictures). It might also have something to do with your flash player. Check the FAQ section for a fix for that. -MG
  6. #406
    Jun 2005
    Dresden, Germany
    The download is new and with the flash player I have no problems. Spinning logos etc. works fine.
  7. #407
    May 2007
    Ok I have read through every page of this thread and all the pages of the simplistique skin thread (more than 50 pages) and I still can't get my speedo/compass working. I will give some specs of my current system:
    I am using WinXPSP2, RR Installer ver 2.0.0.24, Simplistique skin, iGuidance v2.0.1a, Flash 9. System P4 512MB 100GB HD.
    Here is a copy of my menu.ini file:
    Code:
    MEDIACAR Skin
    MEDIACAR menu. Skin
    /, Y,  Back Slider file path
    Y01,"\volume_slider\volume_*.jpg"
    /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
    S01,303,520,215,45,303,520,215,45,H,01,"",013,"MASTER",""
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B04,0,402,348,80,"LOAD;POWERDVD_PLAYER.skin",""
    B03,0,307,270,80,"VIDEO",""
    B08,455,402,350,80,"LOAD;GAMES.skin",""
    B07,530,307,275,80,"WEB",""
    B06,540,212,300,80,"LOAD;IGUIDANCE.skin;iGuidance;C:\Program Files\iNav\iGuidance\iGuidance.exe;!IntellinavWCls!iGuidance",""
    B02,0,212,270,80,"RADIO",""
    B01,0,116,290,80,"AUDIO",""
    B05,520,117,360,82,"LOAD;AVerTV.skin;AVerTV;C:\AVerTV\AVerTV.exe;!AVerTV_Video!AverTV - Video||STOP",""
    B12,632,512,86,87,"VOL+",""
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L03,591,66,120,30,255,255,255,16,"Arial:B","DATE",""
    L02,590,35,200,40,255,255,255,24,"DotMatrix","TIME",""
    /, I, x, y, w, h, Code;INDICATORCODES
    I01,715,512,90,87,"MASTERMUTE"
    B11,547,512,87,87,"VOL-",""
    B10,122,504,106,93,"GAMMA",""
    B09,1,504,108,93,"EXITMENU",""
    L04,421,46,74,35,255,102,0,18,"Digital Readout Thick Upright:B","REMAININGTRACKTIME",""
    L01,10,46,396,35,255,102,0,18,"Digital Readout Thick Upright:B","TAGARTIST||= - ||TAGTITLE||=","SCROLL-LEFT"
    B66,715,70,79,35,"NEXT",""
    L,570,270,56,20,0,0,0,12,"Arial","GPSSPD","CENTER"
    L,500,38,73,20,255,255,255,10,"Arial","GPSHDG","CENTER"
    L,221,67,62,20,255,255,255,14,"Arial","GPSSAT","CENTER"
    /, F, x, y, w, h, Movie name
    F01,274,133,252,332,"clock.swf"
    END
  8. #408
    May 2007
    I tried adding the lines at the bottom below the entry for the clock, and then I tried it above the entry for the clock, and to no avail, it still doesn't work for me. I am using a Holux gr213 usb receiver, which works fine in iGuidance.
  9. #409
    Feb 2007
    Are the GPSSPD, GPSHDG, and GPSSAT, labels working? If not try using Xport3 found somewhere on this site. If they are working, where is your clock.swf file located? To me your menu.skin file would tell me that your clock.swf is located in the same place as roadrunner.exe. If its in a subfolder I think you have to put "\folder path\clock.swf" where you would replace folder path with just the directories below roadrunner. Try that and see if it works. -MG
  10. #410
    May 2007
    Quote Originally Posted by mgswed View Post
    I don't think the labels are working? I do have xport3, I downloaded it is only basically two files, I am unsure of how to work it? I used it, selected my gps and these things still don't work.
    The menu.skin file is in the folder with the skin, where the clock.swf file is located.
    I am going back outside to test this as I uninstalled RR and installed it again, and also installed the latest Beta version of the simplistique skin.
  1. Road RUnner and Navi Voice
    By cdevelasco in forum PowerVoice
    Last Post: 07-20-2007, 12:40 PM
  2. Road runner Ideas (BIG LIST)
    By sephiroth7 in forum Road Runner
    Last Post: 04-01-2007, 09:50 AM
  3. Road Runner Sound Problem
    By Mick300ZX in forum Newbie
    Last Post: 05-23-2006, 07:45 PM
  4. Can I watch video into a Road runner ?
    By shinjetko in forum RR Bug Tracker
    Last Post: 05-19-2006, 12:31 AM
  5. Road Runner Facts...
    By guino in forum Road Runner
    Last Post: 02-21-2005, 11:16 AM
