Page 8 of 48 FirstFirst 123456789101112131415161718 ... LastLast
Results 71 to 80 of 471
Thread: New Road Runner Clocks/Logos (By Tissy)
  1. #71
    Variable Bitrate xs10x's Avatar
    Jul 2005
    Bronx, NY
    Tested the Roadrunner version on my truck. Seemed to work well. I guess when getting a new direction it happens to "spin around" then point to the direction you are going.
    I am comparing this to the digital compass I have on my overhead.
    `¨`¨`¨`¨` _____||¯.\__
    .:.:.:.:.:.:;!_(o)______(o)'i
    TruckputerX - Vortech SuperCharger Vid
    TruckputerX Progress Bar [|||||||||-] 90% Complete [It's never 100% done]
  2. #72
    Newbie WinoOutWest's Avatar
    Feb 2005
    Vancouver, BC
    Quote Originally Posted by grave
    I discover your job and like it
    Actually there's no compass or speedo on bmw.swf and a speedo in Km/h should be great. (not KpH as Mapmonkey)
    Perhaps an ini file to make choices could be the soluce.
    Any possibility to get a new BMW in Km/h with the orange color of Nissan job ?
    Thanks.
    I'll second this request. Using the generic one (in Liquid Smoke's LSX Skin) for now. Being Canadian means km/h would be great as well.
    Nicely done!
    Cheers!
    Wino
  3. #73
    May 2006
    How do I get speed and compass info?
    How do I get speed and compass info? I am using freedrive as GPS program in roadrunner but I can´t get any info in what do I need to do?
    Regards /Jörgen
  4. #74
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Quote Originally Posted by Tissy
    I'm inclined to leave it white as this way when the .ini bit is done, you will only have the one colour to change. Also, if i include to much shadowing on the fonts and other graphical effects it will increase CPU load greatly.
    Steve
    True.
  5. #75
    Nov 2005
    Midlands
    Quote Originally Posted by sdujolo
    Regards /Jörgen
    I'm having the same problem but i use MapMonkey,am i overlooking some thing,am i going to need a port splitter?
    Is it possible changing the name of the file to Clock.swf has stopped it working or some other prob?
    The clock works ok but no satellites,speedo or compass.
  6. #76
    Feb 2005
    Vancouver, BC
    Quote Originally Posted by Griff1
    For me the Clock and Speedo works but the compass does nothing except point north. I'm iGuidance (which is working fine) and Liquid Smoke's skin wich already requires XPORT... do I need to split it again?
  7. #77
    Variable Bitrate Tissy's Avatar
    Sep 2005
    Essex, United Kingdom
    What i had to do with mine is put a couple of labels in the .skin file where the clock module is being displayed.
    For example, put these lables in the menu.skin file (if this is where the flash object is embedded).
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L,570,270,56,20,0,0,0,12,"Arial","GPSSPD","CENTER"
    L,500,38,73,20,255,255,255,10,"Arial","GPSHDG","CE NTER"
    L,221,67,62,20,255,255,255,14,"Arial","GPSSAT","CE NTER"
    You will obvioulsy need to edit the skin and place these labels somewhere out of the way. Also make their RGB values the same as the background they are on so the are invisible. That should then do it for you.
    As i say, this is the way i did it and it worked, others (including Guino) may have an alternative neater solution.
    Let me know how you get on.
    Steve
    System - Epia SP13000 for Main PC, Holux GR-213 USB GPS Receiver SiRF Star III, 2.4Ghz Uplink with VNC and Custom designed USB Intelligent SDC (In DEV). All fed to a Sony CDX-F7500 Headunit via USB. www.wrx-carpc.co.uk
  8. #78
    May 2006
    No data in new clock using roadrunner and freedrive!
    I still can´t get it to work I can´t get values from freedrive to roadrunner.
    I have this line in sdk.ini(freedrive)
    FDSPEED=RoadRunner
    I have this line in menu.skin(roadrunner).
    L05,290,430,50,30,255,255,255,13,"Arial Narrow:B","GPSSPD","Speed"
    Any ides?
    Regards /Jörgen
  9. #79
    Nov 2005
    Midlands
    Steve could i have a version of the BMV2 clock with the Vauxhall logo and vauxhall lettering on the clock and speedo faces please.
    The colour of that clock is perfect except for its not the bezel that looks odd now,its the pale RoadRunner logo.
    I've not got round to adding the suggested labels in the car yet but i'll try it out tomorrow.
  10. #80
    Sep 2005
    Griff1 - Vauxhall BMV2 Clock with white fonts posted on web site as requested.
    Hope you like it.
    Steve
  1. Road RUnner and Navi Voice
    By cdevelasco in forum PowerVoice
    Last Post: 07-20-2007, 01:40 PM
  2. Road runner Ideas (BIG LIST)
    By sephiroth7 in forum Road Runner
    Last Post: 04-01-2007, 10:50 AM
  3. Road Runner Sound Problem
    By Mick300ZX in forum Newbie
    Last Post: 05-23-2006, 08:45 PM
  4. Can I watch video into a Road runner ?
    By shinjetko in forum RR Bug Tracker
    Last Post: 05-19-2006, 01:31 AM
  5. Road Runner Facts...
    By guino in forum Road Runner
    Last Post: 02-21-2005, 12:16 PM
