In RR.ini chek for that line
hidedots=true
Change it to hidedots=false
Also check for
pathlimit=true
When you hit browse, it should go to your default directory
Has anyone seen this, or help me get out of it !
I pointed my Audio Browser to the CD drive to look to see if I can get the CD to autoplay. Anyway, the CD fired up, and Track01 etc was displayed in the System List area of my skin. The problem is I have no dots, or any other way to get back to the hard disk stored music !
Where does RR keep its persistant data ? Or how do I change the list to point at the hard disk again ?
Help . . . . . . .
KPJUK
M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
hidedots=true
Also check for
pathlimit=true
Thanks MGD,
both are set correctly, hidedots=false and Pathlimit =true.
Any other ideas ?
regards KPJUK
Thanks for your help MGD,
I had to set a Browse button on my audio browser screen and keep it pressed in to go to the default directory, then add a BROWSE.RRL file in the Music Directory, and then add an SD box to the Browser page. This now lets me move back at will.
Cheers
KPJUK
Glad you figured it out. I have two browsers in my skin, one for HD and one for CD. I don't use browse.rrl at all. At the enf of the Audio_Browser.skin file I have SD,02,02,153,140,"C:\Music" and in the Audio_Browser_CD.skin file I have SD,02,02,153,140,"D:\" which is my CD-Rom drive letter. Now when I hit browse CD it goes to my CD-Rom drive and when I hit browse HD it goes to my Music library. Works like a charm.
Thats the way I was going to do it, but my Epia M10k isn't the fastest at changing skins, so I thought I would try one of the other approaches suggested in the forums, and thats when my problems started. I have wasted all day on trying to sort this one out !
What OSK do you use for your web browser? I am having trouble getting mine to work, but only on the web browser screen, the GPS is fine ! I am sure I am not doing something right, but what it is God only knows!
Thanks though for your input.
cheers
KPJUK
