Woops, Sorry just realised I put this in completely the wrong section. Can an Admin please move?
Well it maybe isn't advanced but it doesn't seem to be in the forum anywhere so I thought I would ask.
The problem I am having is. I am using browse.rrl to display virtual folders from my music. My setup is this. My browse file is located in c:\rrbrowse (which obviously my music folder in rr.ini points to). The browse entries point to specific folders in c:\media\. Problem is if I click on say albums in browse it takes me to c:\media\playlists which holds sub folders for each letter of the alphabet. The problem is once here I am able to back out to the root.
So my question is is there anyway to stop this bearing in mind I need the back feature but from the c:\media\playlists folder it needs to back to c:\rrbrowse not c:\media? pathlimit=true doesn't work.
Cheers
Hey Cruizer, there is an option in rr.ini that does this, try setting
pathlimit=true
cheers
KPJUK
M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
As I understand it, RR doesnt allow this to happen. Going back will simply take you up a folder level, not back to the folder the RRL file is placed in. And I think the pathlimit will only work if you are within the path set in the config. It will need to be programmed into RR to detect when a browse.rrl is used and somehow remember the path.
I too would like to see this feature added![]()
Jarrod - Holden VX S!
You could just place another Browse.rrl file in C:\media\playlists and have it point to c:\rrbrowse
C:\rrbrowse;>Home<
