Page 11 of 23 FirstFirst ... 23456789101112131415161718192021 ... LastLast
Results 101 to 110 of 222
Thread: Astro (In Progress)
  1. #101
    Dec 2005
    BTW, im downloading IG3 just to try your skin, but its doing really slow, i don know when its gonna finish
  2. #102
    Mar 2006
    Los Angeles, CA
    I really like this skin- just some quick feedback/questions:
    1. IG3 looks fantastic with the way you have embedded it in this skin. However, when I try to go to full screen mode after switching back and forth to, say, the audio player, another instance of iGlaunch (and thus iGuidance) is launched. I ended up with like 4 or 5 instances running! (It also appears that instances after the 1st one do not have access to the COM port so they're useless for navigating) It's of course possible I just have something setup wrong, or it may be a bug. This seems to be the biggest problem I have.
    2. IG3 has a built-in trip computer and some other goodies. While the embedding looks great with the menu bar gone, it unfortunately takes that with it. Since I use a touchscreen only, it's pretty tough to enter keyboard shortcuts. Think it would be possible to set up a button (hidden?) that would allow access to that and maybe even the other 'menu-bar- features' or something?
    3. In the video player screen, I can't seem to find any way to back out of a directory once I get into it. For example, my video folder has 2 folders in it- one for music videos and one for movies/tv for my passenger to watch. If I go into the music video folder, I can't figure out how to back up to the screen that allows me to switch to the tv folder.
    4. Also in the video player- there's a skip fwd (within a video) button but no 'next video' button. That would be really nice to have.
    5. I know you said you had no plans for a web browser skin, but also that you'd consider doing one if people wanted it. I am officially making my polite request here for that
    OK, that's about it. I really like this skin so far and if I can figure out the nav screen problem will try to use it for a 200 mile road trip later today.
    Thanks again for sharing your excellent work!
    -mark
  3. #103
    TMF
    TMF is offline
    Constant Bitrate TMF's Avatar
    Apr 2006
    Waterloo, IA -- cvmusclecars.com
    Quote Originally Posted by MGD View Post
    Here is an update for the Visu people. You have to put an unvisible button on the Audio_Player.skin and call "MENU;Visu.skin" for now untill I update the skin over the weekend.
    Here is shot of it in action and the Zip File.
    Beautiful! I'll plug this in and let you know how it works!
    THANKS!!
    John
  4. #104
    MGD
    MGD is online now
    MGD's Avatar
    Feb 2005
    Los Angeles
    Astro RC1
    The skin is updated. Goto the first Post for the Download Link.
  5. #105
    TMF
    TMF is offline
    Apr 2006
    Visualization kick start?
    MGD,
    The visualization skin is sweet. Thanks again!
    I did have an issue with starting it though. I edited the main skin as instructed and created a button where the album image shows to invoke the new visu.skin.
    That worked and brought it up but Milkdrop did not start. So, I edited the visu.skin as follows:
    MEDIACAR Skin
    MEDIACAR F-CNS(800x600Stretched)"audio Skin
    Visu_off.jpg,Visu_off.jpg,Visu_down.jpg,Visu_down. jpg
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B00,2,80,200,200,"VISU","visualization Kick Start"
    B01,2,6,81,63,"ACTIVATE;Milkdrop||SENDKEY;{SCROLLL OCK}" ,"Lock/Unlock visualization"
    B02,83,6,73,63,"ACTIVATE;Milkdrop||SENDKEY;{ }" ,"Soft cut to next"
    B03,155,6,77,63,"ACTIVATE;Milkdrop||SENDKEY;{H}" ,"hard cut to next"
    B05,231,6,75,63,"ACTIVATE;Milkdrop||SENDKEY;{F4}" ,"vis title text"
    B04,306,6,74,63,"ACTIVATE;Milkdrop||SENDKEY;{F9}" ,"3D Effects"
    B05,380,6,89,63,"ACTIVATE;Milkdrop||SENDKEY;{F2}" ,"Song title text"
    B06,5,529,84,62,"VOL-","Volume-"
    B07,89,529,82,62,"MASTERMUTE","Mute"
    B08,171,529,85,62,"VOL+","Volume +"
    B09,264,530,69,60,"MAIN",
    B10,337,530,84,59,"SHUFFLE","Repeat"
    B11,421,530,72,59,"REPEAT","Repeat"
    B12,494,530,73,60,"PREVTRACK","Last Track"
    B13,567,530,75,59,"PLAY","Play"
    B14,642,530,74,60,"NEXTTRACK","Next Track"
    B15,717,530,76,60,"MENU;Equalizer.skin","Equalizer "
    /, A, x, y, w, h, color;RGB
    A01,1,74,799,428,
    /, Y, Back Slider file path
    Y01,"slider2\slider_*.gif"
    /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
    S01,582,43,193,17,581,43,193,17,H,01,"slider2\Poin ter.gif",30,"MASTER",
    /, I, x, y, w, h, Code;INDICATORCODES
    I01,377,508,14,14,"SHUFFLE"
    I02,448,508,15,14,"REPEAT"
    I03,100,508,63,14,"MASTERMUTE:b"
    I06,587,6,112,31,"GPSVOL"
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L06,710,6,81,33,0,0,0,18,"Concielian","VOLUME","CE NTER"
    END
    I rearranged the Bxx entries (because I'm a neat freak?) and added another B00 to the same area that the album was. Basically, I press it twice and then Milkdrop starts.
    Second: I fixed the soft cut command (B02 above) to remove the extra quotes so that now worked.
    Third, the scroll lock keypress looked wrong so I modified B01 above as well to make it match the other Milkdrop buttons but neither this or the original would lock/unlock the current visualization. Is the {SCROLLLOCK} the correct key command in the skin to pass a real Scroll-Lock key press?
    And finally, is there a way on the main player screen to both call Visu.skin and also invoke Milkdrop at the same time so I can eliminate B00 above?
    Thanks!
    John
  6. #106
    MGD
    MGD is online now
    MGD's Avatar
    Feb 2005
    Los Angeles
    John, download the updated version in the first post. There is a new audio player with a VISU button on it. When clicked the visu skin is loaded and visu starts. Make sure you have the plugin configured in winamp.
    Thanks for the spacebar fix. I looked up the send key commands and it says SCROLLLOCK. Don't know, I will look into it.
  7. #107
    TMF
    TMF is offline
    Apr 2006
    Can't wait to get home and download!
    Thanks again!
    john
  8. #108
    MGD
    MGD is online now
    MGD's Avatar
    Feb 2005
    Los Angeles
    Here is a shot of the new Audio Player. Just click the eye next to the time and of you go.
  9. #109
    Newbie ~Rob's Avatar
    Apr 2006
    UK
    I like! I might give it a whirl when I get my screen back
  10. #110
    MGD
    MGD is online now
    MGD's Avatar
    Feb 2005
    Los Angeles
    New Radio Player
    Just finished the new Radio Player Skin with working indicators for AM/FM and indication of the frequency MHz/kHz.
    Will be in the upgrad this weekend.
  1. Replies: 110
    Last Post: 10-24-2007, 10:32 PM
  2. moto e815.. some progress but more questions!
    By Sonicxtacy02 in forum PhoneControl
    Last Post: 04-24-2006, 04:00 PM
  3. A work in Progress
    By xtraxmechx in forum Car Audio
    Last Post: 02-08-2006, 11:33 AM
  4. 1.6 Progress Report
    By AlienEclipse in forum Centrafuse
    Last Post: 01-04-2006, 05:06 PM
  5. Progress meter not showing
    By Meelobee in forum Road Runner
    Last Post: 07-15-2005, 01:20 PM
