Here are the screens shots
Here is my CFX mod..
Fixed the font sizes for the LCD bar on the top.
Removed Toyota Logos
Added Flash Gauges
Modded External GPS skin for use with Iguidance and IGMON
Let me know what you think
What you need
(1) IGMON 2.0 or higher - Link Here
(2) B8BBOI CFX Skin - Link Here
(3) Iguidance 2.1.1 or higher (for use with IGMON and the Next Turn Label)
(4) CFX Skin Upgrade pack (this thing your reading about) - Download Below
(5) Disable Transistions in your RR.INI by adding this line transition=-1
(6) Compatible resolution = 800 x 480
Instructions:
Copy all files to the CFX skin folder in road runner after uncompressing
Very nice! CFX is still the best skin ever, i've never used 1 skin this long (since release date). One little thingy...: Could u make the speedo in KM/U? We never heard about miles here in Europe![]()
AsRock AM2 dual VGA
AMD Sempron 3000+
512MB DDR
3,5" 80GB harddrive
Liliput 7"
TFT 15"
M2-ATX
0% [OOOOOOOO-] 100%
My install
as far as i know, they use miles in england / great britain...??Originally Posted by Flappy
as the only country in europe, they also drive on the left side of the road :|
correct me if im wrong![]()
Sorry to tell you I did not author the gauges and really dont have the skill to change them.
Follow this link and it has the source in flash there as well.
With a little effort you should be able to figure something out.
Thanks for the compliments..
Flash Guages including source code
Nice work. I was never able to get CFX to work correctly, I'm gonna have to give this a try.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
In order to make it km/h instread of Mi/h all you have to do is change the lable in the flash file and then change your setting in RR or km/h. simple. You don't need to know flash.Originally Posted by JagPuter
Installed
Could u explain that more detailed? I don't understand completely, could be my bad englishOriginally Posted by Quattro
EDIT: Never mind, just installed this upgrade, and it shows KM/u here.... Cool!
Just 1 problem, the speedo has a max of 180KM/u, maybe i can get the meter go round :P
AsRock AM2 dual VGA
AMD Sempron 3000+
512MB DDR
3,5" 80GB harddrive
Liliput 7"
TFT 15"
M2-ATX
0% [OOOOOOOO-] 100%
My install
Well if you're carputer is in the caddy i guess you'll have to really really really floor the paddle to the metal. Guess it's gonna be hard to get it to go over 180EDIT: Never mind, just installed this upgrade, and it shows KM/u here.... Cool!
Just 1 problem, the speedo has a max of 180KM/u, maybe i can get the meter go round :P![]()
