Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 35
Thread: RRHD - Road Runner High Definition
  1. #11
    Maximum Bitrate DiNASTY's Avatar
    Mar 2005
    Concord, California
    P3rv3rt B3ar, thanks for bring that up. XLobby appears to be MUCH lighter than Media-Portal and setup was a breeze.
    some others that I tested are:
    Nero Home Premium
    Intervideo Home Theater Platinum
    Showshifter
    Cyberlink Power Cinema
    Out of all of these though, RR has the most features and potential IMO
    Beer is proof that God loves us and wants us to be happy — Benjamin Franklin
  2. #12
    Jun 2006
    Dinasty - .
    Dinasty...
    I lived (still do in the HTPC arena and you've done a great job of assesment). I actually spent a number of years (still kinda do) with Frodo/Erwin and the Media Portal Team. Prior to that MCE, Snapstream, Xlobby - and all those you've tested and made very good assesments with. Very good.
    Since my transition full boar into the CarPC arena - no doubt RR is king... I actually tried to get all of the HTPC apps to size well for CarPC - and was short-changing myself. I have a completely digital household for the most part and now have my CarPC as an extension of that while parked in the garage.
    Pulling any Recording out of this, i.e PVR functions should be #1 and think that is where you are headed (Xlobby is about the closest to RR as anything there because it does indeed try to act as a FrontEnd - not replace the PVR apps)... What I found as the key areas that would need coded/implemented which could be beneficial for both CarPC and HTPC would (for starters be):
    - MoveDB parsing, i.e. IMDB, Amazon, ... other than that its simply basic browsing and click. Most the good apps support all formats of ISO's and catalog very well. Mount ISOs, Catalog, ....
    - Remote Control - I have not worked much with RR in remote control areas simply because when I swung to CarPC I decided to make the move to touch as well. Meedio (now Yahoo) as do Xlobby - provision for Touchscreen controllers and assume a Dual Mon scenario with TV acting as the main view and the Touch as the controller.
    There is a bunch more, and actually was not going to post here (lazy I guess ) but this forum has been amazing for my ventures into the CarPC and felt I could at least share some input here.
    All in all since Xlobby does not set out to replace a PVR, but run in tandem much as RR would be doing - finding a PVR app that fits snug within (OR) simply using as a backend on Networked PC's in the home to query the Music Archive, and Movie Archive, TV archive... would be where I would see it fitting.
    Just my 2 cents and input
    Thanks for all your work here, it's been a great insight for me as I now have 2 heavy iron CarPC's cookin - natural extension of my home infrastructure, and has kept me busy from my HTPC ventures for a while.
    Thanks...
    Quote Originally Posted by DiNASTY
    Nero Home Premium
    Showshifter
  3. #13
    Maximum Bitrate P3rv3rt B3ar's Avatar
    Jul 2005
    Funland
    Well the xlobby takes a little time.. to get yourself familiar with... especially cause documentation is unexisting at worst and lousy at the best. But once ur starting to get into it, u realize its huge potential... not only it has drag and drop skinning interface, which makes skins adaptable even for non-skinners like myself, but it also has its internal scripts which u make with matter of mouse clicks, and with them u can define any button to take any possible actions, which not only command xlobby, but also launch external software and control them.
  4. #14
    Jun 2006
    One of the things RR has that is nice, as does Xlobby - is the ease of skinning. Where RR goes a step further - is the TieIN with MPC - and the ability to not only tightly integrate MPC into a skin, but pull the progress data, status bars for vol/duration/misc, as well as all transit controls. Xlobby still struggles here a bit - and ZoomPlayer is preferred but RR one ups them in this area which still kinda blows me away.
    Some good skinners at Xlobby - as many if not better here - different flavors. The IMDB lookup and MovieDB engine - (again I can't speak for the Remote Control piece) if placed in RR would then likely prop RR above an Xlobby and then could be represented as such - and those skins would make a ton of sense and easy to code.
    The apps struck me as similar but have to tell you RR is an incredible piece of work - and as Dinasty has mentioned - is really bordering in that arena.
    Quote Originally Posted by P3rv3rt B3ar
  5. #15
    Jul 2005
    Funland
    Quote Originally Posted by kolemieux
    Ive made a plugin for this purpose. It integrates ZP to XLobby. It provides progress data to Xlobby, and makes jump with progressbar possible. Among other features. Its currently still on my personal use, theres still one feature and two major bugs i want to implement and hunt down before public release.
  6. #16
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    this is definately a cool idea. Ive found though, RR runs a bit sluggish for me at 1920x1200 (native res) with transitions on, and just ok with transitions off.
    I toyed with the idea a while ago, but i really think before i would venture down that road i would really need some hardware accel to take advantage of the power i have available. MCE2005 runs so silky smooth for me, but there are some things in RR that are way better like playlists and queing up media ect where MCE really falls short. And areas of MCE that really shine compared to RR like the online spotlight,picviewer although RR's pic viewer is really close. TV support would need to be fully intergrated.
    But i long for the day when RR shifts focus a little in this area. Compared some of the other non mce htpc apps RR is nippin at there heels already.
    beer replenishment fund
    mp3car live search
  7. #17
    Low Bitrate jollyeskimo's Avatar
    Apr 2005
    Toronto
    Well, with enough work, of course RR could be turned into a top notch HTPC/PVR suite, but that's up to guino... and while it may be good for HTPC's, it might not be good for carPC's since it takes attention from the original purpose of RR.
    RR would need the addition of at least a tv recorder component and online guide feed parser/scheduler, and that's no small addition.
    Just curious, in addition to the HTPC suites you've mentioned...have you tried GBPVR? I've used MCE05 and BeyondTV before, but I'm using GBPVR now since it's free and works well enough for my needs.
  8. #18
    Jun 2006
    Ditto...
    Ditto ---
    The PVR Timeshift engine especially when done like Media Portal is some insane coding..... The team on MP works about 7*24 and every tini tiny little issue comes up - and requires serious coding and chews up a ton of time.
    If RR was to fit well here it would be as a "front-end" for MCE Recording, or other PVR solutions - ReplayTV is in Beta now as a SW/PVR as well.
    RR could slip in and replace XLOBBY if the MovieDB was added in, and a few other areas like Remote Control missing pieces...
    However - would hate to see the focus of what RR does so well get lost in the shuffle - and what I've loved about this forum and the work done here.
    All very good points...
    Quote Originally Posted by jollyeskimo
  9. #19
    Aug 2003
    Chicago
    ive tried a few, looked at a lot but to be honesty i dont think there is one single HTPC app that is doing it right. MCE05 is close but has some shortcomeing that are supposed to be addressed in vistaMCE, but only time will tell. I cant gather up the courage to sacrafice any of my pcs to install vistabeta2, maybe when they ship a RC ill give it a try. But so far i think all the other htpc apps are far behind MCE.
    I too wouldnt really want RR to concentrate on the htpc market. To do it right would require a massive amount of time.
    mp3car live search
  10. #20
    Jul 2005
    Funland
    Well, if paint is sufficient for u why to use photoshop
  1. problems with video + road runner.
    By nealric in forum Road Runner
    Last Post: 01-14-2006, 09:37 PM
  2. Road Runner Crashes - Please Help
    By julikop in forum Road Runner
    Last Post: 01-14-2006, 11:31 AM
  3. Road Runner Menu Resume
    By faichiu in forum Road Runner
    Last Post: 12-24-2005, 02:05 PM
  4. High quality Road Runner logo?
    By b8bboi in forum RR Skins
    Last Post: 10-07-2005, 10:55 PM
  5. Replies: 5
    Last Post: 05-25-2005, 06:38 PM
