The K8055 interface board has 5 digital input channels and 8 digital output channels. There are also two analogue inputs and outputs with 8-bit resolution. The number of inputs/outputs can be further expanded by connecting up to 4 more cards to the PC?s USB
connectors. All communication routines are contained in a Dynamic Link Library (DLL). You can write custom
Windows (98SE, 2000, ME, XP) applications in Delphi, Visual Basic, C++ Builder or any other 32-bit Windows application development tool that supports calls to a DLL.
# 5 digital inputs (0=ground, 1=open) (on board test buttons provided)
# 2 analogue inputs with attenuation and amplification option (internal test +5V provided)
# 8 digital open collector output switches (50V/100mA max.) (on board LED indication)
# 2 analogue outputs
# 0-5V, output resistance 1K5
# PWM 0-100% open collector outputs max. 100mA/40V (on board LED indication)
# General conversion time: 20ms per command
Power supply through USB: 70mA approx
# Diagnostic
software with DLL included
# Dimensions (WxHxD): 145x20x88mm
