Originally Posted by
CdRsKuLL
Hi m8.. I've just been thinking whats needed whilst I've been out doggie walking.. I do try to keep everything simple and straight forward, but I dont like messing to much with peoples install.. so I would like your views before tomorrows release...
Things that need to be set for things to work...
Picture Path in rr.ini in the main Road Runner folder
This needs to be set so RR knows where to show the pictures from, this is regardless in any skin.. its easy to do just open up rr.in in notepad and add something like - picspath=D:\My Pictures\
Everything will work.. but things that will improve things are setting the time to HH:MM in rrconfig, hidedots=true in rr.ini turning the preamp/eq to ON in winamp and a few more things.. I can do most of these from Freedom on startup but unsure if everyone would want this.. it would however save any problems..
So theres only really 1 line you need to make sure you have in the rr.ini file that points to your picture folder path.. everything else I can take care of if you think I should..
let me know
CdR
