When i stat RR is says "Automatic Setup has been done, Please Restart Road runner" then i restart and the same thing keeps popping up!!!
Hi,
skin works very nice, but i have a stupid question, where can i set the path for the picture directory, and can you please explain me the think with the mixer line names? I don´t unterstood, what you are meaning. Sorry for the stupid questions, but i hope for help!
Thankz
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Waited patiently for weeks now... and it gets to 7.4 to 7.8 mbs of 7.9, and freedrive.co.uk resets connection, or I end up with corrupted zip file. Tried with firefox and IE, even tried in a virtual machine with no antivirus software
Anyone else have this issue? Thanks for releasing it! Been following everything.
EDIT: Must be popular... transfer rates jump around, weird waits... I got it on my 12th attempt. Thanks!
91 Stealth RT/TT
CarPuter: Inspiron 5150 P4 3.0ghz; Built-in WiFi; Deluo GPS; Radio Shark; OBD1; Nostromo Speedpad
Audio: Audigy 2 NX; Clarion 500.5 amp; 100.2 center channel amp; Kicker Solo-baric L7 10" Sub
Display: Lilliput 7" Touchscreen
Seems like a simple one when I look at the complexity of this very impressive coding.......![]()
Where do you put the zip code for weather??
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
It seemed to pull that one from my RR config - but the clock it did not and is showing the 24hr clock...
CDR - you mentioned giving us some skin elements for added pages that were not flash. Example - customizing an IG skin which would be nice to have the buttons, art, and an idea on that - most could be figured out however with the elements...
I LOVE YOU!!! This skin is sooooooooooooooooooooooooooooooooooooooooo clean!
yeaaaaa!!!!![]()
that'one is beautiful,
I've installed it and it seems that Freedom works great![]()
the only problem for me is that I don't know where I have to set the picture path (maybe in rrconfig??), the rest seems to work fine.
thank's a lot Cdr![]()
Chrysler 300C Touring 2006 CRD
My ex car - Alfa 147 project
Italian Rock Band! http://www.pikasso.it
I'm having some problems with the butons on the mixer page. When I select one of the top 3, (Main, EQ, Lines) they toggle between each other, not select the right option.
Main toggles Main and Eq
Eq toggles Eq and Lines
Lines toggles Lines and Main
Also, what skin do you recomend for Freedrive? Will you be going one to match Freedom?
Thanks again for all the hard work, it looks great.
