Page 51 of 101 FirstFirst ... 414243444546474849505152535455565758596061 ... LastLast
Results 501 to 510 of 1002
Thread: 'Freedom' skin beta progress (Flash Based)
  1. #501
    May 2006
    I have notised some weird tings, when trying to use osk.
    - When using apps in lauch skin, enter dosent work.
    (used notepad and mIRC)
    - Web with firefox, letters are duplicated and when trying to type to google search (at toolbar) only last letter is entered (and duplicated). Enter dosent work here too.
    Edit: Well enter doset work at any skin, sorry about that.
    Jan 2006
    CDRskull, Thanks for the info regarding the AVS settings but now I have another question regarding the games. I'm trying to use a gamepad and I'm not getting anywhere. I've tried two seperate controllers (Wireless and connected) and they don't seem to respond. I've confirmed they are working in Control Panel but I get nothing when trying to use them for Space Invaders. I've never tried playing any games so this is completely new to me. Am I missing something? I would really like to use my rumble pad 2 with the games but what do I need to do in order to get it to work?
  3. #503
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    cdr, any chance of supporting Power DVD?? (i am being greedy?)
  4. #504
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    will including something in the next release.. ( If I remember )
  5. #505
    Newbie Staggie's Avatar
    Apr 2006
    Adelaide, Australia
    Sp13000 Speed issues
    Hey all,
    Just an update with my testing. It is definatly the suckie onboard graphics causing the problem... I put in a 128mb Geforce FX5200, and the skin runs at about 90% of the speed that it does on my P4 3ghz.. so it is definatly usable now...
    Cheers,
    Kym
  6. #506
    Apr 2006
    Greece
    any one knows of a good tutorial to make a flash button to send commands to RR. I need to add some tiny buttons in Cdrs skin so my steering remote can work correctly..as i have configured it in girder to replicate button presses.. those buttons in my BMV2, were hidden(no button image) tiny, and standard in all the .skins..so the remote will always work regardless of the loaded skin.. any ideas how to add buttons?
  7. #507
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    you dont need a tutorial really. In swishmax, you just set your your button to run fscommand("YOURRRCOMMAND") on button release. it automatically sends the command to rr.
    Here's an example. Command here is SEARCHFILES
    Code:
    on (release) {
    fscommand("searchfiles");}
    Live mp3Car Facebook Chat
  8. #508
    Feb 2004
    Manchester
    Quote Originally Posted by Nomader View Post
    unsure how girder works.. but if you can get it to run a file when a button is pressed, then why dont you use exec.exe that comes with roadrunner, its a command line app which uses roadrunners sdk.. so for example when you press a button girder would do..
    exec.exe VOL+ which would turn the volume up in RR.. then you wouldnt need to amend any skins and it would work 100% all the time.. you would just use the normal RR commands like you do for its buttons
    CdR
  9. #509
    Apr 2006
    Greece
    Quote Originally Posted by CdRsKuLL View Post
    CdR
    cdr i might as well do that..why didn't i think of that. will try it and tell you how it will go
    EDIT: it seems that girder can execute an EXE file but will not accept anything after that.. so it will accept running "exec.exe" but not "exec.exe vol+"
    anyway i made girder send keyboard sentences and that works great.. so i can now use CDRs skin directly without moding it.. (is that fun or no fun? ). thanks cdr
  10. #510
    Feb 2004
    Manchester
    did a hour or two work on it.. and since Guino has got back.. things are looking up :-)
    ok this is now added and tested.. you can now add a extra 3 paths, so say you have a second harddrive.. cdrom or a usbpen. you can now goto the audiobrowser page and press and hold the root key and it will open the below options.. where you just press which you want and it takes you there.. to go back to the normal list you just press the root key. The drives are configured in the menu.txt file..
    &hdpath=C:&
    &cdpath=D:&
    &usbpath=E:&
    simple.. I have also added a eject button on the cdrom icon, just incase you need it :-)
    CdR
  1. Simplistique Skin Release - download and screenshots
    By lloydy in forum RR Released Skins
    Last Post: 12-07-2010, 08:32 PM
  2. Flash based commercial front end discussion
    By DavidL in forum Other Cool Front Ends
    Last Post: 04-05-2006, 03:20 PM
  3. "System Error(Blue)" beta skin D/L Now
    By systemerror in forum RR Skins
    Last Post: 09-16-2005, 01:28 PM
  4. Skin based on Vladien's Land Rover Skin
    By SpacemanSpiff in forum MediaCar
    Last Post: 01-02-2005, 01:49 PM
  5. ** New Flash Based Media Player **
    By jcraig in forum Software & Software Development
    Last Post: 08-20-2004, 11:58 AM
