A quick Question CDR...
Since I'm running IG, and have followed the "IG native in RR" thread where u posted another updated RR.EXE, how will this work with the 2.0 version...
Your a very very good man CDR![]()
my TURBO! Altezza!
ATEZZA / IS200 3SGE-TURBO 6SPD MANUAL , EPIA 13000, 512 RAM W/LAN , 100GIG , GPS , TOUCH, 3X LCD, FLUSH TOUCHPAD MOUSE, SOUNDBLASTER EXTERNAL
Swedish site for CarPC's
http://www.bilpc.info
attached powerdvd skin.. can you give it a go for me please.. you will need to alter the menu.txt to launch it.. ta
Lots really, Guino has been adding alot of code for freedom.. so until matrix or guino sort stuff out, release source etc.. you will have to wait for matix to play catch up..
CdR
Lo m8,
Any chance of being able to make the volume indicator appear if using keystrokes as I use my steering stalk connected to a keyboard controller to change track and volume but I can never see where the volume is up to. If not, will come up with another way of showing the volume.![]()
CdR,
The vol looks sexy man...
I have tested the power dvd skin and its nearly working sweet, apart from Play/Pause does nuthin. and the skip chapter forward and back do the same as step forward and back. I'm assuming it just uses shortcut keys so just to save ya some time n = next chapter, p = prev chapter, space = pause, enter = play... (dunno if u can do the different key presses on the different button state, but when the dvd is stopped pressing "space" doesnt do a thing), also the play/pause button is buggered, showing both pics at the same time..
also i have had a look at the play/pause button state, (fixed my problem from earlier today) but the apps, skin & settings skins have the same problem, stays on play all the time... i have checked all 3 .skin files and the "STATUS" line is there on all three..
Cheers,
Kym
newer power dvd have different shortcuts than older..since power dvd support was one of my requests as well..here is the .skin i use for power dvd 6.0 in MC2.0
check it out Cdr. and keep up the good work
i am using the mixer button for changing subtitles (which is a must) ( i didn't have time to edit the psds so the button has MIXER on it still) and the MC logo for "Title menu"..
