Page 64 of 101 FirstFirst ... 14545556575859606162636465666768697071727374 ... LastLast
Results 631 to 640 of 1002
Thread: 'Freedom' skin beta progress (Flash Based)
  1. #631
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Keep this thread full of links to the thread on Freedrive.co.uk as it gets updated... Exposure problem cured
  2. #632
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    CdR could you tell me what the label in the pic is for,puzzled.
  3. #633
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Quote Originally Posted by Griff1 View Post
    lol..thats a debugin variable so I can see whats going on.. O well a new version will be out soon with playlist / cd / usb / 2nd harddrive support.. ALSO for you Destinator 5/6/pn .. lol what ever you want to call it I have built in support for it including a on screen keyboard... now I have hidden the buttons behind the map, so in order to see them you will need to comment/uncomment acouple of lines in the skin.. below is a picture of it anyway. I have made the whole top right part of the screen a 'hotspot' for GPS full as well as I have added the indicators now.
    CdR
  4. #634
    Nov 2005
    Midlands
    Thanks mate,looking sweeter every day.Thats good news about the osk too.
    i'm looking forward to the 5th.
  5. #635
    Nov 2005
    Midlands
    CdR,off topic,What tuner are you using now? The radioshark or HQCT?
    I'm just after a review of the radio quality your (as a uk resident) getting (from either).
  6. #636
    Feb 2004
    Manchester
    Hi m8.. I have both to be honest, the HQCT seems a bit better but I still need to mount it right and check out the quality of aerial extention cable I'm using.. I think because its cheap crap thats not shielded its not doing what it should. I am quite please with it, but at the moment the reception is only about 60% of my old h/unit but thats 60% more than I had before..
    hope this helps :-)
    CdR
  7. #637
    Nov 2005
    Midlands
    That does help thanks.
    Another thing i was wondering about,will the command used for the internet icon be configurable?
    I only ask cus i use the "exists" command,i'm not sure how other apps do it.
  8. #638
    Feb 2004
    Manchester
    At the moment I'm just using rr's ONLINE indicator which seems to work fine, what did you have inmind before I spend a day duplicating the indicators over to the rest of the swf files.
    CdR
  9. #639
    Variable Bitrate Philhop's Avatar
    Apr 2006
    Sorry CDR was reading back on your post and id assume you wanted me to check out your Powerdvd skin and some serious ****zzle went down in hospital. So I didnt get the chance, just playing with it more.
    It would be good if it had fullscreen video , dvd , and vis support in 2.0 it just minimizes it back into the window.... its one feature that im really killing for lol
    my TURBO! Altezza!
    ATEZZA / IS200 3SGE-TURBO 6SPD MANUAL , EPIA 13000, 512 RAM W/LAN , 100GIG , GPS , TOUCH, 3X LCD, FLUSH TOUCHPAD MOUSE, SOUNDBLASTER EXTERNAL
  10. #640
    Nov 2005
    Midlands
    The exists command shows actual connectivity,AutoNetDetect and similar apps create a document (by polling google,if it connects it create's a document) which the "exists" command checks for,if it exists the web icon appears.
    "online" however will show connected if your system has an enabled LAN,modem or BT whether you have a connection or not.
    Its nice to have it setup that way if your driving around looking for a hotspot.
    If there's any way the skin command could be in the ini or something for that purpose.
  1. Simplistique Skin Release - download and screenshots
    By lloydy in forum RR Released Skins
    Last Post: 12-07-2010, 08:32 PM
  2. Flash based commercial front end discussion
    By DavidL in forum Other Cool Front Ends
    Last Post: 04-05-2006, 03:20 PM
  3. "System Error(Blue)" beta skin D/L Now
    By systemerror in forum RR Skins
    Last Post: 09-16-2005, 01:28 PM
  4. Skin based on Vladien's Land Rover Skin
    By SpacemanSpiff in forum MediaCar
    Last Post: 01-02-2005, 01:49 PM
  5. ** New Flash Based Media Player **
    By jcraig in forum Software & Software Development
    Last Post: 08-20-2004, 11:58 AM
