Page 66 of 101 FirstFirst ... 16565758596061626364656667686970717273747576 ... LastLast
Results 651 to 660 of 1002
Thread: 'Freedom' skin beta progress (Flash Based)
  1. #651
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by CdRsKuLL View Post
    have you updated the rr.exe and your flash in the car ?.. Your really border line using the M2.10k really, a external vga card may help
    What about a M2.12k ???
    Terran
  2. #652
    Maximum Bitrate pyros's Avatar
    Mar 2004
    Toronto, Canada
    I'm using the rr.exe provided with the skin and I am running Flash 8 in the car... I'd love an external vga card.. but there's no room :P My PC is in-dash, behind my lcd :/
    After using it some more, once the skin is already loaded it's not too bad. Bearable, however teh screensaver doesn't seem to work.
    Also, I have some good news about the XM part... sending you a PM in a sec
    2004 Ford Mustang Mach 1
    Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
    Install Status: DONE
    My XM FAQ
  3. #653
    Mar 2004
    Toronto, Canada
    Here's an XM screencap teaser, should be easy for SIRIUS too....
    My XM FAQ
  4. #654
    Newbie Staggie's Avatar
    Apr 2006
    Adelaide, Australia
    Quote Originally Posted by ccsnet View Post
    Terran
    I've got the SP13000 and the onboard vid has major issues running this skin... I put in a 128mb FX5200 and it runs at about 90% of the speed it's suppose to with the card... Hope this helps.
  5. #655
    Jan 2003
    Quote Originally Posted by Staggie View Post
    I'll take that as a no then
    Terran
  6. #656
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    I have been spending all night revamping alot of my code.. as I noticed it was getting a bit laggy on my carpc.. I have removed afew effects and also redone ALOT of the main code.. it now flicks between tracks very fast and without any problems. I have also added a position track slider now, for those that load big playlists.. which I have also coded in :-) unsure if I will make the release date due to all this recoding and stuff I need to redo.. but its defo faster if it helps
    btw.. the slider background aint finished as I'm not happy with it..
    CdR
  7. #657
    Jun 2006
    Sexy .....
    CdR
  8. #658
    Apr 2005
    Queens, New York
    CdR
    Hey CDR, let me ask you, what kinda mobo/processor do you have??
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  9. #659
    Feb 2004
    Manchester
    I'm running a Gigabyte S754 uATX board with a sempron 3000 in it.. came to about £90 in total I think.. including a boxed original + fan sempron.. :-) its never missed a beat and its got the nvidia 6100 graphics on it which is awesome.. + sataII but I aint using that with the 2 1/5 drive. All powered via a M2. Faster and cheaper than any epia board about.
    CdR
  10. #660
    Feb 2004
    Manchester
    ok the audio slider is all done.. two reasons for adding this..
    1. Because playlists have been added it was taking ages to move up and down them.
    2. When I get round to adding XM Radio, again the list can be quite long.
    It lists the current track number from 1 to the length of the list.
    O yeah it slides in and out and the track counter follows the slider level
    CdR
  1. Simplistique Skin Release - download and screenshots
    By lloydy in forum RR Released Skins
    Last Post: 12-07-2010, 08:32 PM
  2. Flash based commercial front end discussion
    By DavidL in forum Other Cool Front Ends
    Last Post: 04-05-2006, 03:20 PM
  3. "System Error(Blue)" beta skin D/L Now
    By systemerror in forum RR Skins
    Last Post: 09-16-2005, 01:28 PM
  4. Skin based on Vladien's Land Rover Skin
    By SpacemanSpiff in forum MediaCar
    Last Post: 01-02-2005, 01:49 PM
  5. ** New Flash Based Media Player **
    By jcraig in forum Software & Software Development
    Last Post: 08-20-2004, 11:58 AM
