Results 1 to 4 of 4
Thread: Menu timeout
    FLAC djmickyg's Avatar
    Feb 2004
    Menu timeout
    if i make a menu popup usuing
    "menu;name.skin"
    is there anyway i can set a timeout for the menu so after so many seconds of the menu being open and no activity it will go back to the previous window automaticly?
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    There are two commands you can use.
    /, (IDL) Idle Timer
    /, Seconds
    IDL,XXX
    The above defines the number of seconds in "IDLE" state (no mouse/keyboard actions) to
    execute the "IDLE" event that can be defined in ExecTBL.INI so a command is executed at such time.
    /, (TMR) Timer event
    /, Seconds
    TMR,XXX
    The above defines the number of seconds after loading the screen RR will wait to
    execute the "TIMER" event that can be defined in ExecTBL.INI so a command is executed at such time.
    This event is re-occurring, so every few XXX seconds it will re-execute the TIMER event. You can use
    a simple variable switch to prevent it from executing your command more than once (if desired).
    Put this in the name.skin file you want to have timed.
    IDL,5
    and put this in exectbl.ini
    "IDLE","EXIT"
    Now, when there is no movement of the mouse for 5 sec. the screen will be closed.
    Feb 2004
    very nice..
    worked like treat.
    thanks
    Low Bitrate frangolfgt's Avatar
    Jul 2006
    Lancs, UK
    Am i dumb or something? why wont it work for me?
    ExecTBL.ini i added this line:
    "IDLE","EXIT"
    and in my skin files:
    /, (IDL) Idle Timer
    /, Seconds
    IDL,5
    it does exit but exits on 5 seconds from opening that skin even if not idle, so i can be click and moving my mouse and it still exits.
  1. RR Menu to emulate MM Menu button
    By GizmoQ in forum Map Monkey
    Last Post: 09-05-2006, 03:02 PM
  2. Centrafuse 1.6 Bugs
    By Mbai2 in forum CF Bug Reports
    Last Post: 05-10-2006, 11:30 AM
  3. Menu position (for multimonitor)
    By Scouse Monkey in forum FreeDrive
    Last Post: 07-04-2005, 05:37 PM
  4. Menu always on top, other new features
    By clean customs in forum FrodoPlayer
    Last Post: 01-22-2005, 05:27 PM
  5. How to setup gps button in menu
    By Tyrael in forum Media Engine
    Last Post: 02-25-2004, 03:53 PM
