Results 1 to 5 of 5
Thread: Simple question/Commnad
    FLAC mauri's Avatar
    Jan 2004
    Simple question/Skin Commands
    What solution/ sequence of commands for mute the Radio sound after I have press the "PLAY" button in one different screen of the default " Audio Player", for play one song?
    Mauri
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Under the code for the play button you need a double pipe and the mute command.
    "PLAY||MUTE;WAVE"
    instead of wave you need to call the line where the radio is playing on.
    FLAC mauri's Avatar
    Jan 2004
    Quote Originally Posted by MGD View Post
    "PLAY||MUTE;WAVE"
    I have tried this:
    "MUTE:LINE||PLAY"
    but not solution for my question...
    But:It's ok the ";" or ":" after MUTE command?
    In the Readme by Guino have write "MUTE:<line to mute>"
    ...I check if your revers solution work, thanks.
    update:
    Tried, in all the ways doesn't work.
    I write LINE, LINE IN , whit ";" or ":" (my radio work with Line In) but mute all sound and not volume for the song.
    Mauri
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Here is the part from the newest Skincommand.txt
    "MUTE" - This allows you to mute/unmute ANY audio line (Based on it's name).
    Example: "MUTE;Wave"
    "SETVOL" - This allows you to set the volume of any mixer line do an immediate value from 0 to 100. This is mostly useful as "ATT" function or when used from Flash/SDK.
    Example: "SETVOL;Wave;50" (Sets the Wave line volume to 50%)
    Special names also available ar:e FREQX and PREAMP (Range of 63-0), WINAMP (Range of 0-255)
    You can use the "SETVOL" also.
    "SETVOL;LINE IN;0||PLAY" or use
    "MUTE;LINE IN||PLAY
    FLAC mauri's Avatar
    Jan 2004
    "MUTE;LINE IN||PLAY
    It doesn't work,this two settings tested mute ALL sounds... strange, the commands that you say should work,and Mute only the Line In....
    Mauri
  1. Simple Checklist
    By Chuck in forum Road Runner
    Last Post: 01-31-2006, 02:38 AM
  2. A simple front end!???
    By wilsonj in forum Software & Software Development
    Last Post: 01-07-2006, 05:08 PM
  3. simple e-mail software
    By felix99 in forum Software & Software Development
    Last Post: 09-21-2002, 04:29 PM
  4. simple LED circuit.. did i do this right?
    By ShinkunoNamida in forum Off Topic
    Last Post: 06-04-2002, 12:23 AM
  5. Need a simple playlister
    By Ed in forum General Hardware Discussion
    Last Post: 09-02-1999, 09:51 AM
