Results 1 to 9 of 9
Thread: album art not showing up...
    Low Bitrate jollyeskimo's Avatar
    Apr 2005
    Toronto
    I've been trying to play around with a skin, and no matter what I try, the album art element doesn't show up when I load up the skin in RR even when I place it on the top or the bottom of the items list in the skin editor. Is there something I'm missing?
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    you need to add a J,x,y,w,h ie..
    J,50,100,100,100
    and I think you will also need to a a ALBUMART label.. ie..
    L15,0,0,0,0,128,255,128,18,"Arial Narrow:B","ALBUMART",""
    CdR
    Apr 2005
    Toronto
    Ok, gave that a try:
    Code:
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L11,0,0,0,0,128,255,128,18,"Arial Narrow:B","ALBUMART",""
    /, J, x, y, w, h
    J01,549,064,170,170
    But still getting no love... any ideas?
    May 2006
    I had to enable Show Icons in RR.INI and make sure the hidden and system attributes weren't set on the JPGs
    Good luck,
    Rich
    Apr 2005
    Toronto
    Quote Originally Posted by RichP714 View Post
    Good luck,
    Rich
    Yep the settings are all in order. Album art works in other skins as well...
    Feb 2004
    Manchester
    post the whole .skin file and lets have a look
    Apr 2005
    Toronto
    shazam!
    Attached Files Attached Files
    May 2006
    Looks like you have two J01's defined...the first one looks like a combination of expressions for the J (album Art) and R (album text art) tags.
    You probably don't have any album text art, and just want the JPG album art to show, but the first J01 is on top and therefore blank...try deleting it
    Apr 2005
    Toronto
    Yeah I just want the jpg to show up at the coordinates... but I just deleted the top J expression, to no effect.
    edit: just did some more messing around, and it seems that the playlist was actually covering the entire item, so it was displaying just fine.
    So now the question is, is it even possible to put these album covers over other objects like playlists and text? Because it seems to be not working no matter in what order I code the audio_player.skin. This skin used to work just fine too.... could it be because of a new RR.exe that has caused this change?
  1. Album Art for StreetDeck
    By god_of_cpu in forum StreetDeck F.A.Q.
    Last Post: 05-31-2008, 04:16 PM
  2. Album art downloader
    By hijinks21 in forum Software & Software Development
    Last Post: 07-20-2006, 09:56 AM
  3. Replies: 18
    Last Post: 03-12-2006, 05:56 PM
  4. Select album to play via album art
    By xGumbyx in forum Mobile Impact
    Last Post: 01-25-2006, 07:46 PM
  5. yet another album art not showing
    By DonkeyBoy in forum RR Skins
    Last Post: 11-23-2005, 11:59 PM
