Results 1 to 7 of 7
Thread: SkinReloader (realtime) - ? - for SkinDesign...
    Jun 2006
    Guino - all...
    Not sure this is possible now, perhaps I am missing a hotkey or step - but if not would be nice. I've used other apps in the past that had skinning implementations that allowed for side-by-side design and reload.
    All it really does is allow a hotkey to reload the skin elements upon and edit (you have editor or make changes in another window) and vs having to reload RR the hotkey would reload the skin and allow for faster skin design ...
    Is this already present and I've missed something? If not would make for a nice add if at all possible with the RR architecture...
    Thanks for consideration...
    Maximum Bitrate kpjuk's Avatar
    Dec 2003
    West Midlands
    Smile
    Hello kolemieux,
    the command you want is "RELOADSKIN". Just create a button on your skin and give it this command.
    cheers
    KPJUK
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    The iDrive skin has a config program which allows you to add or remove certain options and then when you press apply it RELOADSKIN.
    Jun 2006
    Dang - can u believe I did not think of that.... It's the same for skin changing. Thanks for that tip I should have realized it - major help......
    Thx again...
    Quote Originally Posted by kpjuk View Post
    Hello kolemieux,
    cheers
    KPJUK
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Put:
    116,"RELOADSKIN"
    In your keyTBL.ini and restart RR, then just press F5 to reload the skin, or use whatever key that you want by using the keycode.exe in your RR folder to get the keycode associated with that key and replace it with the 116 in the line above
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Jun 2006
    Thanks much !!!!
    Put:
    116,"RELOADSKIN"
    Dec 2003
    West Midlands
    Nice one Blue ZX3, I never thought to do that !
    cheers
    KPJUK
  1. realtime window capture program
    By lostreception in forum Software & Software Development
    Last Post: 08-14-2005, 07:27 PM
