Results 1 to 7 of 7
Thread: item ordering
    Low Bitrate jollyeskimo's Avatar
    Apr 2005
    Toronto
    item ordering
    So I'm editing a skin, and I'm trying to put album art on top of a section that normally has a small selection of labels.
    Is there a way to arrange the items so that when an album cover for the mp3 is found, the album cover is displayed ON TOP of the labels (purty), rather than having the labels go on top of the album art (not purty).
    Here's my .skin file... obviously I've tried arranging the J element and the L elements with respect of each other, to no effect.
    Using RR 8/10/2006.
    Code:
    MEDIACAR Skin
    MEDIACAR F-CNS(800x600Stretched)"audioplayer" Skin
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B01,0,0,58,58,"MENU;Lighting_Menu.skin","Lighting"
    B02,744,0,58,58,"VIDEO","Video"
    B03,011,137,066,067,"VISU","Visualisation"
    B04,077,137,065,067,"SHUFFLE/REPEAT","Shuffle/Repeat"
    B05,142,137,066,067,"MIXER","Mixer"
    B06,11,205,65,67,"MASTERMUTE","Mute"
    B07,77,206,64,67,"VOL-","Volume-"
    B08,142,206,066,067,"VOL+","Volume+"
    B09,0,323,77,73,"PREV","Prev/RW"
    B10,78,323,65,73,"PLAY","Play"
    B11,144,329,66,67,"SCANMODE","Scan"
    B12,0,397,77,83,"NEXT","Next/FF"
    B13,78,397,65,83,"ACTIVATE;iGuidance||GPS","GPS"
    B14,144,397,66,83,"LIST","Playlist"
    /, S, x, y, w, h, forecolor R;RGB, G, B, backcolor R;RGB, G, B, played color R;RGB, G, B, selected color R;RGB, G, B, select color R;RGB, G, B, trs, font size;FONT, font name
    S01,225,64,494,411,255,127,000,000,000,000,255,000,000,000,000,000,255,255,255,TRUE,14,"OCR A Extended"
    B15,732,135,62,56,"PGUP","Page up"
    B16,732,192,62,56,"UP","Up"
    B17,732,249,62,56,"GOTOFIRST||SEARCHLIST","Search"
    B18,732,307,62,56,"DOWN","Down"
    B19,732,365,62,56,"PGDOWN","Page down"
    B20,732,422,062,057,"EXIT","Exit"
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L01,025,018,135,024,255,127,000,20,"DS-Digital:B","TIME","left"
    L03,165,016,470,035,255,127,000,20,"OCR A Extended","TRACKNAME","scroll"
    L02,640,018,135,024,255,127,000,20,"DS-Digital:B","DATE","right"
    L04,14,64,180,19,255,255,255,011,"Arial:B","PLAYLIST","Playlist"
    L05,14,83,90,19,255,255,255,011,"Arial:B","STATUS","Status"
    L06,104,83,90,19,255,255,255,011,"Arial:B","KHZ","Track freq"
    L07,14,102,60,19,255,255,255,011,"Arial:B","CURRENTTRACKTIME","Current track time"
    L08,74,102,60,19,255,255,255,011,"Arial:B","TRACKTIME","Total Track Time"
    L09,134,102,60,19,255,255,255,011,"Arial:B","KBPS","Track bitrate"
    L10,138,292,060,016,255,255,255,010,"Arial:B","VOLUME","Volume"
    /, I, x, y, w, h, Code;INDICATORCODES
    I01,743,66,41,30,"REPEAT"
    I02,743,97,41,30,"SHUFFLE"
    I03,036,213,014,012,"MASTERMUTE:b"
    I04,150,339,50,36,"SCANMODE:b"
    /, A, x, y, w, h, color R;RGB, G, B
    A01,225,064,494,411,000,000,000
    /, J, x, y, w, h
    J01,0,62,220,220
    END
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You need to use the flash file posted in the release thread.. it displays the album art if existent (on top of anything), and is empty (or shows logo.swf if existent), when no album art is present.
    Ride Runner RR's Myspace
    Apr 2005
    Toronto
    OK I've tried using the flash album art...
    But now, all of my Label elements under the art.swf have disappeared (they haven't been removed in the code).
    Also, button presses on buttons under the flash (when no album art is loaded) are delayed indefinitely until a some other down/hover bitmap (not in that area) is triggered or a different screen is loaded.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    umm.. sounds like I'll need to make something to show different info on labels based on indicator states (i.e. if album art exists). Then we can simply blank out the labels and they'll look as if were hidden.
    Outside of that, the only thing you could do with the current version is to make the labels in a flash object or blank out the labels by using the "ONSONGSTART" event along with the new BYIND command .. it could get messy though.
    Apr 2005
    Toronto
    Well it's not really that big a deal....the text isn't too distracting. It's just one of those perfectionist deals... the skin editor/code format just somehow gave me the impression that there was some sort of layering/order based on the order in which the code was written.
    I'll try blanking the labels out onsongstart, and failing that... give up/wait until you do it
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The album art used to be layered on top.. but that was a side effect of using VB controls for drawing the album art. This stuff is long gone now that most of the image drawings is API based for better memory efficience and improved performance. I took the decision to change it based upon the fact that, At the time, it was only a choice between album art and flash logo in the current skins (nothing with text on it).
    Apr 2005
    Toronto
    Ahhh that's what I figured in the back of my head... because I used to use Kuo's skin for a very long period of time, with one very very old build of RR (didn't update for a lonnng time). No wonder it used to work back then.
    I've only been updating RR frequently this while since my install is in between cars. Which is what brought up the whole album art issue... being covered by the playlist and text labels. Heck I originally didn't even notice for a while that it disppeared since the original placement was on top of nothing but playlist area.
  1. NMEA extraction AppleScript need help
    By zapwizard in forum MacCar
    Last Post: 05-05-2006, 02:10 AM
  2. Someone ordering at digitalww?
    By DJSmiley in forum Classified Archive
    Last Post: 04-30-2005, 04:49 PM
  3. Started Ordering Parts!!!
    By edrex in forum General Hardware Discussion
    Last Post: 02-12-2005, 05:10 PM
  4. I keep ordering power wires that are too short!!
    By hd54321 in forum General MP3Car Discussion
    Last Post: 01-01-2005, 10:18 PM
  5. Deluo Ordering
    By trdcpu in forum GPS
    Last Post: 05-03-2004, 03:40 AM
