More Screenshots
Ok, well I decided to get off my blue brushed metal kick and go a bit darker with my newest revision/rebuild of my skin. Officially I guess this is CobraSkin_08...I'm not really creating this for the masses, but as with my last skins that had a few hundred downloads, I figured I'll release what I've done/am doing and you can take it from there if you so choose.
DOWNLOAD THE SKIN: -HERE- Currently 10.7 MB
NOTE: This skin is not yet complete, so the download isn't either, but I'm posting what I have so far, and the download will be updated with each new skin as completed. Also, this archive contains MY root Road Runner folder and setting, so don't just extract the full file into your Road Runner directory. I've done this because I'm including SonicXtacy02's TrafficCam program, lostreception's GPSGAS plugin, the Web Browser plugin, Prefect's 1ClickWebCamRecord, and more with my skin. This way the functionality will remain without needing to make too many changes. Check out my "RR.INI" and "ExecTBL.ini" files to see what you need to add to yours. Copy the GPSGAS and LiveTraffic folders to your Road Runner folder.
If you get a "file not found" when trying to download it's probably because I'm uploading a new and updated version of the skin/archive.
This skin is still in progress and I'll update as I complete the skins. Once I'm finished, or at least mostly there, I'll release the PSDs.
PSDs - Download
MAIN MENU - (Cobraskin 08 - MAIN MENU PSDs (ON-OFF). This includes the ON and OFF PSDs for the MAIN MENU only. I'll release ALL PSDs once completed.)
Skins/Menus Completed Thus Far (and in the download archive):
Main Menu
GPS / iGuidance
Audio Player
Audio Browser
Playlists
PopUp Volume Control
WEATHER
CDRIP (updated skin)
Traffic Cams (by SonicXtacy02)
PicViewer
GPS Gas (by lostreception)(if you've never had this before, it's best to download/run his install program so that the required ocx/dll files are registered with your system)
Video Player & Browser
DVD Player (using VLC media player - controls of skin mapped to hotkeys of player)
1ClickWebCamRecord (by Prefect)
Web Browser Plugin
To Come:
Extended Weather Detail
Skin Browser
WinTV and FM
Vehicle Maint??
If there is something you'd like me to add to this, let me know.
SCREENSHOTS:
Would work nicely with my Mustang
One comment: The blue text in the Weather screen is very hard to read. You should use a lighter text on a gray background. The green you used on the same screen worked nice.
Added PicViewer & TrafficCams (by SonicXtacy02)
from a vet and fellow virginian nice skin. how about vehicle maint? Keep up the good work![]()
