Results 1 to 9 of 9
Thread: Alphapad as POPUP for Album Browse..?
    Jun 2006
    Guys -
    Can this be done? I am trying to create a AudioBrowser skin but to save skin space on the page, launch the AlphaPad as a popup via Menu; ....
    Do those selections end up in neverland or can I do this in such a way so the AudioBrowser skin page will recieve those?
    Sorry if this is stupid - I have the popup all working but did as a test and before I dive into this too much wanted to see if I was out of luck?
    Thanks guys !!!
    Jun 2006
    AlphaPad as popup ..
    I should have been more clear... I mean an aplhapad like LS uses in LSX but is on the bottom of the AudioBrowser - or Astro uses in that skin. Essentially a keypad to narrow down your audio sort ABC DEF HIJ .... But execute as a PopupMenu vs within the skin page itslef, then get out of the way.
    I am looking at the NUMOSK and other examples "similar" but wonder if this cant be done?
    Sorry if the post was unclear....
    Quote Originally Posted by kolemieux View Post
    Guys -
    Thanks guys !!!
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    it can be done as a popup but you will need a button for all letters because you can not switch back to the popup where you left off.
    Button would be "MENU;Audio_Browser.skin||SKIPTO;A"
    Jun 2006
    Thx MGD, let me work from there --- I assumed from your Astro skin and LSX this was not an easy task or you guys would have done this. I am either going to do that or use another skin page to emulate the popup process.
    Thanks for the response!!
    Quote Originally Posted by MGD View Post
    Jun 2006
    MGD - PopUp coordinates...
    MGS - I did not ask this earlier as I figured it would be an easy find... my bad. Do you have the coordinates syntax for MENU popup loads... or a post - example - i saw your one post with timouts syntax.
    I will keep searching and know LS uses this in VOID so am looking there as well.
    Thx - sorry
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    in lsxvoid it uses switch buttons, im not sure if it can be done in a pop up or not, i never tried, just seems like an extra step added to the mix to me.
    are you trying to add the popup from the audio player or from the audio browser?
    beer replenishment fund
    mp3car live search
    Jun 2006
    LS,
    I actually am working from some of your work in LSX --- what I wanted to do to maximize usable screen and since I don't need this up all the time, a button or hotspot that will bring up a small SMS/ALPHAPAD as a popup to get me in the list where I need - then drop out. Also, by doing this I can use larger buttons and know they will get out of the way...
    Any input would be appreciated ... I have a few workarounds to accomplish this but that is the reason I am doing this...
    Thanks guys
    Quote Originally Posted by liquid_smoke View Post
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Like I sayed before, you can not use the SWITCHBUTTON command in a popup menu. You need to have a button for every letter in the popup to browse by alphabet.
    Jun 2006
    ? - I agree, coding it. Not disputing that at all and much thanks for the syntax. Helped me with exaclty what I needed.
    Thx MGD
  1. Replies: 2
    Last Post: 04-07-2008, 03:22 PM
  2. BTStackServer PopUp on call
    By Jeeve5 in forum PhoneControl
    Last Post: 07-21-2005, 02:55 PM
  3. RR 03-09-05 .. Multiple Browse ..
    By guino in forum Road Runner
    Last Post: 04-18-2005, 01:22 PM
  4. Replies: 0
    Last Post: 03-24-2005, 01:17 PM
