Page 5 of 10 FirstFirst 12345678910 LastLast
Results 41 to 50 of 93
Thread: Progress Report on Freedom v3.0
  1. #41
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    43
    Quote Originally Posted by empezza View Post
    At the top of the screen the music track details are displayed. As you have said that this area is not scrollable, can you make it two lines? First line, Artist - Album, and second line, Trackname. I think this would fit in the space OK, but if it looks too crowded, just drop the font size a tad.
    i kinda like the clean look of only having the song title on the top bar. Should i want to know the artist and other info i've created an info button that pulls this up for 15 seconds. Beats the hell outta waiting for the audio player skin to load (takes forever when ur entire music catalog is the playlist)
    Live mp3Car Facebook Chat
  2. #42
    Nov 2005
    Nice idea.
    Is 15 seconds too long? I would have thought 3-5 would be enough perhaps.
    Does the info screen fade in/out? (ie: flash based)
  3. #43
    Mar 2005
    Sweden/Vaxjo
    Quote Originally Posted by Sonicxtacy02 View Post
    Looks damned nice, wanna share it, maybe something for version 3 of freedom...
    Swedish site for CarPC's
    http://www.bilpc.info
  4. #44
    Woodbridge, VA
    Blog Entries
    43
    Quote Originally Posted by Iceman_jkh View Post
    Nice idea.
    i put it at 15 just because it gives me time to use my rate or transfer buttons. How long its displayed is completely up to the exectbl.ini setting. It fades in and out but not because its flash, only because of the EFFECT setting in rr
    Quote Originally Posted by Naesstrom View Post
    i can share it no prob. Just know that the info button isnt apart of the main.swf freedom uses, its a transparent button on top of the gamma button (that i dont use). Also, the ratings stars only work with a script i wrote as a part of my ratings plugin. That part can be removed just by modifying the images and removing the label. I should also note that this script uses TMR and POS settings.. so if you use skineditor know that those settings will be erased each time you save
    http://www.sonicxtacy.com/song_info_skin.rar
  5. #45
    Nov 2005
    Request:
    Is it possible to have a button on the AUDIO screen that turns "Gap Killer" On/Off?
    I have a lot of electro CDs that are one session of music spread over a few tracks and the 'loading pause' gap really ruins them.
    Ive found 2 ways to fix this:
    1) Put a tick in "Remove Silence at beginning/end of Track" feature (set at -24dB) under the 'OTHER' tab in DirectSound [out_ds.dll]. This fix gives pretty good results so far.
    2)Use a 'gap killer' output plugin (eg: out_nogap.dll or out_cw.dll). These also give excellent results so far.
    The only problem with this is that when I listen to classical/rock/Hiphop/etc the gap killer process ruins any track where there is a legitimate point of silence by cutting to the next track immediately
    Is it possible to have a button (toggle) which selects between two different output DLLs on the fly? [IE: default is out_ds.dll and Gapkiller ON is out_nogap.dll]
    Having a button for this feature would help fix this problem and greatly benefit the electro listening community - because its impossible to change on the fly in the car.
    Cheers
  6. #46
    Low Bitrate Flappy's Avatar
    Jun 2004
    Netherlands
    I'm sooo happy with your skin now, yesterday i upgraded my install to a AMD Sempron 3000+ (with AsRock dual VGA mainboard), en it runs sweet!
    2 thingy's: The colors are a bit dark. Perfect for night skin, but for day i like happy colors Like in Proximo's CF skin. I know nothing about flash, so i don't know if it's 'easy' for you to make more color theme's.
    I will use the skin anyway, but it would be a nice feature if i could select color schemes from the menu or so.
    2nd, is it possible to change the roudrunner text in the main menu and splash screen? I like to personalise the skin with car-brand and stuff.
    Thanx!
    AsRock AM2 dual VGA
    AMD Sempron 3000+
    512MB DDR
    3,5" 80GB harddrive
    Liliput 7"
    TFT 15"
    M2-ATX
    0% [OOOOOOOO-] 100%
    My install
  7. #47
    Jul 2006
    Jervis Bay, NSW Australia
    An INFO button sounds good to me!!
    Max Perry
    Acer laptop Pentium M 735 1.7Ghz, 1.25Gb RAM, 64Gb solid state drive, Windows 7 32-bit
    Lilliput 8" LCD 829GL
    Garmin Mobile PC GPS
  8. #48
    Constant Bitrate vortex's Avatar
    Feb 2005
    London, UK
    I think it would be better if it just auto scrolled instead of an extra screen and if possible using the scroll setting in rr.ini to determine the type/direction of scroll.
  9. #49
    Woodbridge, VA
    Blog Entries
    43
    Quote Originally Posted by vortex View Post
    Um the reason the scroll isnt there is because it cant be made to scroll lol
  10. #50
    Nov 2005
    That 'text scroll' is for the LCD output I believe.
  1. 'Freedom' skin beta progress (Flash Based)
    By CdRsKuLL in forum RR Skins
    Last Post: 01-18-2007, 11:39 PM
  2. 1.6 Progress Report
    By AlienEclipse in forum Centrafuse
    Last Post: 01-04-2006, 04:06 PM
  3. 1.1.3 Progress Report [Updated 5th Nov]
    By Ninja Monkey in forum Map Monkey
    Last Post: 10-31-2004, 12:03 AM
  4. Frodoplayer Progress Report 14 Dec 2003
    By frodobaggins in forum Software & Software Development
    Last Post: 12-21-2003, 10:16 PM
  5. Frodoplayer: Progress Report
    Last Post: 10-14-2003, 10:21 PM
