Results 1 to 4 of 4
Thread: Input fields
    Maximum Bitrate kpjuk's Avatar
    Dec 2003
    West Midlands
    Cool Input fields
    Hi guys,
    I want to get around to skinning a better input screen for Infomap Navigator. Is their a way in RR to have a data input field where I can park data, address, postcode etc, and then string it together using Sendkey as the interface mechanism, or do I need to use VB, AutoIT to make it happen ?
    cheers
    KPJUK
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Something similar is done in the "Map_Point_GPS_Location.skin" , but it is done "behind the scene" and I do not know how. This MAY help point your question to "How is it done on the Map Point skin" and hopefully provide an answer.
    The only other way I could think of is to save each field into a variable, then just concat the variables into a single string/variable.
    Not too helpful I know, just thinking of ways to approach it......
    My Fiero Build Thread
    Dec 2003
    West Midlands
    Jesus John, I can't keep up !
    That was how I was planning on tackling it, but wanted to use RR input fields, with a button at the bottom of the form that concatenated the strings and passed them to the app.
    I guess I can use a series of TextBoxes, like on the OSK as input fields to do this with, I've still got can't see the wood for the trees syndrome !
    cheers
    KPJUK
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Have a look at the RREarth skin -- I did just that.. all you have to do is put a label on top of a button, have the button pull out the OSK to set a variable, display that variable on the label and have it sent out with a command later on. This is how the GE_GETDIRECTIONS function was all built around. Very simple variable use.. you can definitely "concatenate" the variables as parameters when running your application.. "RUN;C:\myapp.exe|$VAR1$$VAR2$" etc..
    Ride Runner RR's Myspace
  1. Help! Lilliput changed input, I am missing buttons
    By Snootch in forum LCD/Display
    Last Post: 10-11-2009, 10:37 PM
  2. Replies: 15
    Last Post: 08-21-2007, 04:46 PM
  3. Requests
    By CdRsKuLL in forum FreeDrive
    Last Post: 08-11-2006, 06:09 AM
  4. Replies: 10
    Last Post: 06-07-2006, 10:13 AM
  5. HELP, Input Signal to AMP
    By Power_nisse in forum Car Audio
    Last Post: 06-22-2005, 12:35 PM
