Hi,
you can add a command in Exectbl.ini to do this, or whenever you start that screen do a "GESTURESOFF||LOAD;Troublesome_Screen.skin"
Make sure on the exit button you add
"GESTURESON||Exit" to turn it back on when you exit the screen
cheers
KPJUK
This is probably a newb question, but then again i'm a newb!so here goes:
I'm doing some skin work and i want to run the GESTURESOFF command each time a certain screen loads because the NG command isn't working right for me, (with lostreception's draw swf). Any help out there?
-Ross
02 Camaro SS
Opus 150W($150 used) Morex Venus 668 Case($109) Epia M10k($166) 128 Megs ($0), Maxtor 200Gig($76) CD-R/DVD($29) Lilliput 7"($285) Buffalo Airstation($42) Holux GPS($53) GM10-AUX(audio input, $72)
Tot: $983
Buying stereo!
Hi,
cheers
KPJUK
M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
thanks very much, worked just like a charm.
-Ross
02 Camaro SS
Tot: $983
Buying stereo!
