no reason the "screensaver" has to be done in flash, you can create a screen with album art etc, setup a command for it and use Menu or Load for the screen , use a Idle timer for the screen and even setup a keyboard shortcut that will turn it on/off. You can also set it up so it only pops up if you are on specific screens so it wont interfere with IG etc. You can set visibility on the screen also if you want it tranparent.
here is an example of how im doing it.
The middle area is the "screensaver" area, i also have a visual running in the same area. It only shows up if you are in the audioplayer screen and no activity for 60sec
LinkBack URL
About LinkBacks
