Results 1 to 7 of 7
Thread: Popup Skin Menus?
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    Popup Skin Menus?
    Is there a way to create a pop up skin menu wherever you want it.
    IE, the exit menu pops up and is often small. I can make it bigger by making the image bigger. But what if I wanted to move it to the side? Or to the bottom of the screen.
    Or a audio slider pop up wherever I want it on top of another skin. This is whats missing for that real polished OEM style look. Pioneer z1 does it just fine.
    Car : 00' Chrysler 300M
    Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
    Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
    CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    The best advice i can give is,Have a dig around inside your current skin for the Exit menu and see how its been done.
    Create a backup of the popup image and change it.
    It helps to download a few skins and pull em apart so to speak,see how the button codes work and such.
    Here's a link to the skin editor = http://innovatedaudio.com/griff1/RRSkinEditor.zip
    Good luck.
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    You can have the menu popup wherever you want. Here are 2 screens with the exit menu popup at the center and the 2nd one with the /POSX and /POSY commands in the skin file.
    In the exit_Menu.skin put this code
    /POSX=25
    /POSY=25
    Sep 2006
    Georgia
    Quote Originally Posted by MGD View Post
    /POSX=25
    /POSY=25
    thanks, but still dont know how to force a new type of popup menu. adding POS commands to the skin i want to move around just shifts the entire screens perspective. Screwing things up.
    Sep 2006
    Georgia
    well i finally realized i had skincommands.txt
    checked it out
    command i needed is
    B,570,103,62,81,"MENU;Whatever.skin;Whatever",
    works well. Will make everything much easier now
    I was using the Launch command before and that just wont do
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    /POSX=25
    /POSY=25
    Place these values at the top of the *.skin file
    I used a pop up menu in my drop skin.
    New Age Garmin - Skin for RR
    Aug 2006
    West Allis, WI
    I was able to make it look like a drop down menu with this method.
  1. New skin
    By Floatingpi in forum CF Skins
    Last Post: 12-22-2007, 01:31 PM
  2. Mauri RR skin
    By mauri in forum RR Skins
    Last Post: 12-06-2007, 10:50 AM
  3. Replies: 2
    Last Post: 11-21-2006, 04:22 PM
  4. Popup Skin - Just Messing Around
    By 65coupei6 in forum RR Skins
    Last Post: 09-17-2006, 07:51 PM
  5. FrankenSkin (first skin)
    By chrishick in forum RR Skins
    Last Post: 06-24-2005, 12:53 PM
